Keeps going into sleep/hibernate mode even though I've gone into the settings and turned all I could, in my settings, off. If I can't fix this, It's going in the trash...
SOURCE: XG-91D (Black) 19 in. Flat Panel LCD Monitor
Partition shows up as a MS-DOS partition
This utility is designed save information you may be working on when it goes into sleep mode or when your battery becomes low on power.
Computer questions and answers listing 700 - 800
CH000735, How do I disable the power, sleep, or wake buttons in Windows?
Good Luck, please dont for get to Vote, Thank You.
SOURCE: Emachine 19" Widescreen Flat-Panel TFT-LCD Monitor
Your power/inverter board is in need of an overhaul.
The capacitors are failing and possibly a transistor.
If the screen showed any redness or pink whebn it was working, Then
there is a slight chance that one or more of the 4 lightbulbs in the
screen was going bad and finally went.
If you take it apart and send me a picture, I may be able to tell by looking at it.
I repair these boards on ebay
bammbammfran
SOURCE: Dell E173FPc 17" TFT when turned on goes black
Hi Gaz,
First, verify the monitor is functional.
Monitor STFC (Self Test Feature Check)
Turn off the monitor
Plug the monitor power cord directly into the wall socket to remove any surge protectors or APCs from the troubleshooting equation
Unplug the monitor video cable from the back of the computer
Turn on the monitor
The floating dialog box should appear on screen against a black background.
If the issue appears during the STFC, the monitor is defective. What are the results please?
SOURCE: my computer shutdown and im using a emachine e17t6w tft lcd flat
Hi
Dear sir,
Moniter Modale No E700,
E700 modeleprablem, Power splay prablem, but transister, Divaid all componets ok
Becouse power on that puse shout way to andstrading the prablem, please solve prablem
