2007 Dodge Ram Truck Logo
Posted on Apr 09, 2009
How to play dvd while driving
They want $50.00 to make it play while driving. What are they going to so I can do it myself? I have a bypass switch set up and when the truck is in park i switch the button and the video will play. If i put the truck into drive or any gear it says there is no signal. How do I fix this. This is my first installation so I don't know much about it just what I have read. The dvd player is a valor its-702w
Anonymous
Level 1:
Problem Solver:
  • Contributor 6 Answers
  • Posted on May 13, 2009
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
6
Questions
0
Helped
2433
Points
13
There is one wire on the harness that controls this....read the labeling for the wires and cap it off.....every player is different.
My 2002 Dodge Durango will not go back into all wheel drive from four wheel drive can I bypass the switch or what to do to get it out of 4 wheel drive
all wheel drive is four wheel drive , i think you mean back to 2 wheel drive , no way to bypass the four drive switch , have to take to a transmission specialist
Car stalls on a cold start what could be the problem?
Check fuel pressure. If ok; replace the Idle Control Valve. Auto Zone has it for $46.
DVD screen change to GPS during driving after handbrake release.Appear after handbrake on.
for safety reason you are not supposed to watch dvd while driving.Bypass hand brake switch and dvd will be active on driving but please do this at own risk.
21helpful
HOW DO I BYPASS MY 2010 DODGE RAM TRUCK FRONT DVD SYSTEM.
hey buddy have you found a way to unlocck the dvd bypass to watch dvd while driving?Im also looking for a way.
Can I somehow bypass the ignition switch so I can
There is at least 5 main wires on that car, I would recommend going to the junk yard and replacing it
Radio will not play out of the spekers.
Sounds like your amp is bad. If I where you, I would just bypass the amp. If you got dvd player, your screen is an amp in itself. Just find 8 wires that are about foot long and bypass that thing.
Service enginge light on turns traction off
Most likely a bad wheel bearing, or wiring to the wheel bearing. I would start by having it scanned to point you in the right direction. (What bearing to look at). Could also be something in the ABS module.
What is brake wire bypass code
on your dvd player there should be a wire color coded as stated in the owners manual. It should tell u which wire to hook it to.
17helpful
2answers
2008 crysler town and country dvd player
While in park, get the movie playing. Then press on the "Audio" button. This is the button that displays the speaker balance (front, back, left, right). While the audio display is still showing, put the car in drive (or reverse to back out and then drive). Once you are underway, press on the "Audio" button. The video will continue to play up front while you are driving. You have to do this each time, but its not that big of a deal. Obviously this is for the front passenger's use, and not intended for the driver.
Rides rough on road
Ball joint , front shocks , Steering arm bush.
Top Dodge Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Dodge Expert? Answer questions, earn points and help others
