Pump is a 3 horse and on a timer to turn on and off. usually on daily about 12 hours for a large waterfall feature. it was working fine then it did not turn back on the next day. I checked the timer and breaker and both were on but no water flow and pump would not start. when I flip the breaker off, then back to the on position, all I get is a humming noise for maybe 15 seconds then a click and it shuts off .
thank you
Has the motor seemed a little slower in starting than usual? If so then you probably have a weak or defective motor capacitor. Try switching out with a new one.They are inexpensive.Try to turn the motor shaft at rear (under end cap) while it attempts to start. If the motor kicks on then replace capacitor.
1 Press the ON/STAND-BY button to turn the power on.
2 Press and hold the CLOCK/TIMER button.
3 Within 10 seconds, press the or button
to select "ONCE" or "DAILY", and press the MEMORY
button. Set the clock to the correct time if "ONCE" or
"DAILY" does not appear.
4 Within 10 seconds, press the or button to select
"ONCE SET" or "DAILY SET", and press the MEMORY
button.
5 To adjust the hour, press the or button and then
press the MEMORY button.
6 To adjust the minutes, press the or button and
then press the MEMORY button.
7 Set the time to fi nish as in steps 5 and 6 above.
8 To select the timer playback source (CD, TUNER, USB,
iPhone/iPod, TAPE or AUDIO IN), press the or
button. Press the MEMORY button.
When you select the tuner, select a station by pressing
the or button, and then press the MEMORY
button. If a station has not been programmed, "NO
PRESET" will be displayed and timer setting will be
canceled.
9 Adjust the volume using the VOLUME control, and then
press the MEMORY button. Do not turn the volume up
too high.
10 Press the ON/STAND-BY button to enter the power
stand-by mode. The "TIMER" indicator lights up and
the unit is ready for timer playback.
11 When the preset time is reached, playback will start.
The volume will increase gradually until it reaches the
preset volume. The "?" or "DAILY" indicator will blink
during timer playback.
12 When the timer end time is reached, the system will
enter the power stand-by mode automatically.
Once timer:
The timer will be canceled.
Daily timer:
The timer operates at the same time every day. It
will continue until the daily timer setting is canceled.
Cancel the daily timer when it is not in use.
