Cars & Trucks Logo
Posted on Apr 09, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Need instructions on how to remove the door interior panel on a ford e150 to service/replace the door lock solenoid. The door lock intermittently fails to respond.
Jimmy James
Level 2:
Sergeant:
Champion:
  • Expert 260 Answers
  • Posted on Apr 09, 2009
Jimmy James
Expert
Level 2:
Sergeant:
Champion:
Answers
260
Questions
0
Helped
96989
Points
763
Look for the phlips head screws in arm pad area and around panel. Once removed you can pry off panel but be carefull not to break plastic clips if you do no sweat they are cheap to replace.
2answers
How do I hotwire a 1999 Ford e150
Remove the door handle bezel.Remove the power window/door lock switch bezel.Remove the rearview mirror fastener trim cover.Remove the 4 door trim panel retaining screws.One that was behind the mirror trim cover,behind the switch panel,behind the door handle bezel,and one at the bottom corner.Lift the door trim panel up from the door to disengage the trim panel clips.Remove the front radio speaker. Disconnect the power mirror wiring connector.Remove the 3 bolts to the mirror.
How do i remove inside rear door panel on fiesta 2015
Ford Fiesta Plastic Interior Door Panel Removal Guide ...
www.paulstravelpictures.com/Ford-Fiesta-Interior-Door-Panel-Removal-...
Ford Fiesta Interior Door Panel Removal Guide How to take off the plastic interior door panels in a 6th generation 2009-2015 Ford Fiesta to upgrade the ...
Ford Fiesta inner door panel removal (I removed the top one ...
www.fiestafaction.com/.../44959-Ford-Fiesta-inner-door-panel-removal-...
Jan 19, 2015 - 10 posts - ‎3 authors
This is an excerpt from the manual: Remove the rear door window glass. ... Route theinterior door handle cable and door lock actuator electrical connector through the ...Last edited by WildmaninME; 01-19-2015 at 07:41 PM.
Ford - door panel removal - fiesta - YouTube
? 2:19
https://www.youtube.com/watch?v=1URT13Yusjg
Oct 19, 2013 - Uploaded by one2three
this is the removal of a door panel from a ford fiesta 2001. ...Replacing Broken Inside Door Handle on 2007 Ford Fusion - Duration: 5:32. ... Ford Fiesta 1.25 2004 - Cleaning and adjustingrear brake drums - Duration: 8:47.
How To: 2012+ Ford Focus Rear Door panel removal(SE,ST ...
1helpful
2002 Sequoia automatic locks/auto lock buttons no longer work - all doors affected
You possibly need to reprogram the lock system to match your fobs.
If it unlocks by the interior switches then its the fob programming. This site is one example you can look for. http://www.chadspictures.com/automotive/How-To-Program-Toyota-Key-Fob/ If this is not the issue the computer that does the door locks could have died or you can look for the door lock fuse or a cut or pinched wire (due to other damage in an accident or from prior mods you did). Other possibilities include intermittent door solenoids if you can use the interior switch you can click it open and closed until you find the one that does not work every time. Change it out as it can leave your vehicle unlocked or it might interrupt the system. worst case it could be the chassis computer this site sells some http://www.automotix.net/usedautoparts/2008-toyota-sequoia-chassis_computer-product-i88489256n.html?gclid=CKfowo60gb8CFQQOaQodGqUArQ . If the shift lock system is screwed up it could be casing issues also but that's a long shot.
1helpful
2answers
How to replace front outside door handle 1997 ford I bought the handle, but need instructions on how to install it.
Generally, the interior door panel must be removed to access whatever method the manufacturer used to install the handle. i know this isn't a complete solution, but once you get the interior panel off, the rest should become pretty clear.
I need the fuse box diagram
1. Run codes for the air bag light. This is a hard fault and must be remedied to make the light go out. Nothing you do in the fuse box will fix this.
2. Intermittent interior lights are most likely to be caused by bad door jamb switches. And again nothing you do in the fuse box will fix this.
Hope this was of help.
2helpful
Need detailed diagram of 1998 latch mechanism to remove connections from it
there is no diagram... the latch is also a non-servicable latch, so if your problems in the latch- it needs a latch. i would look more closely at the outside door handle itself as i have seen a few of them break on the E series vans.you may be able to get detailed instructions thru autozone.com or @ autozone. hope this helps and good luck
11helpful
2answers
Remove door panel on a Ford Van
For a 1999 Ford Econoline 150 (assume the same or very similar), remove triangular plastic cover over mirror assembly by prying straight out, remove plastic door handle cover by prying up from the front side, remove electronic door switches by prying up from back side, remove round plastic cover at bottom rear of door panel. Four screws are now revealed, remove them. Lift door panel straight up, clips are hooks (not snap in). Work door switch assembly out of door panel. Set door panel aside. Reassemble in reverse order.
9helpful
How to remove the door panel on a 96 Ford Thunderbird?
Carefully pull front door trim panel finish panel away from front door trim panel.
Disconnect wires from front door lock switches, outside rear view mirror controls and window regulator control switches, if equipped. Remove front door trim panel finish panel.
Remove front door trim panel retaining screw through front door trim panel finish panel opening.
Remove interior lamp lens cover.
Remove screw through interior lamp opening.
Slide front door trim panel upward to disengage hooks.
Rotate top of front door trim panel away from front door and lift bottom hooks from front door.
Disconnect window regulator jumper wire
Remove front door trim panel.
3helpful
1999 Econoline E150 Van mirror replacement
1helpful
Rear Door Electric Lock buzzing and stuck
It's the power lock solenoid. There is a tiny plastic piece that connects the solenoid (motor) to the door lock mechanism (thin metal rod or two). Likely, the plastic piece has become disengaged. This is by design so that if there is a problem with the mechanism the motor does not burn out. You will need to have the interior door panel removed to gain access to the interior of the door and the lock rod and solenoid need to be reconnected. The plastic clips used to go for $1-$2 when I worked in auto parts.
Top Ford Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Ford Expert? Answer questions, earn points and help others
