SOURCE: Replace Water Pump on Speed Queen Washer
did you look at the front panel if you tip the machine to the back and look at the bottom of the panel you will see 2 hex head screws remove them and lift the panel out and slide it down some machines others you have to remove the top
SOURCE: Hello. I have a commercial Speed Queen top load
try checking the where the water hoses connect that water valve is where the water is shut off, turn off the water facuet undue the hoses and look inside the valve does it have calcium buildup? or sand in it? if it does you will have to pull the water valve to clean it in order to get it to work correctly. Let me know if you need more help and thanks for using fix-ya.
SOURCE: Coin-operated Speed Queen washer: Model swtt21wn
speed queen double front load washer spinning without stop,please give some idea,thanks alot
