Computer will not start,audible alarm every 5 seconds
Factory made MESH computer.Went to switch on the other day,no output on LCD screen. An audible alarm sounds every 5 seconds.Video card RADEON X 700 series as been tested at PC world and is working.Details of computer.
AMD athlon (tm) 64 processor 3500+
BIOS : ASUS A8NE-FM ACPI BIOS revision 1005 07/19/2005
MOTHERBOARD A8NE-FM (AUSTEK)
Installed RAM X2 512 MB system memory
SOUNDCARD: Realtek AC 97 audio
looks like they didnt fix the computer-nevr bring a car to a dealer-techs are inxperiencd---get a data stream run thats displays values so a good mech can decyfer--may need that computer reflashd w factory gear
Power Output Diagnostic Mode
You may use a power output diagnostic mode in the multifunction alarm module in order to run a quick test on the operation of the following outputs:
• The courtesy lamps control
• The inadvertent power control
The power output diagnostic mode activates after you perform all of following actions:
• Close all of the doors.
• Set the park brake.
• Turn the ignition switch to RUN.
Before 15 seconds pass, perform the following steps:
• Open the right front door.
• Cycle the headlamp switch from OFF to PARK three times.
During a normal operation, the multifunction alarm module will flash the interior lamps until the ignition switch turns OFF. If an internal short occurs in the multifunction alarm module, the module will chime in the following patterns:
• One chime every 3 seconds implies an inadvertent output failure.
• Two chimes every 3 seconds implies a courtesy output failure.
These are the instructions taken directly from the DDY062 manual: Alarm mute for the PROGRAMME END The alarm for the programme end may be muted as follows: IMPORTANT The dishwasher must be ALWAYS off before start this procedure. 1. Hold down the "PROGRAMME SELECTION" button and at the same time switch on the dishwasher by pressing the "ON/OFF" button (a brief audible signal will sound). 2. Keep the "PROGRAMME SELECTION" button pressed for at least 15 seconds (during this time, 2 audible signals will sound). 3. Release the button when the second audible signal sounds (3 "PROGRAMME SELECTION" indicator lights will come on). 4. Press the same button again: the 3 indicator lights (which indicate that the alarm is activated) will start flashing (to indicate that the alarm is off). 5. Turn off the dishwasher by pressing the "ON/OFF" button to confirm the new setting. To turn the alarm on again, follow the same procedure.
Could be several things You'll have to rule out each by using the process of elimination.
1. Unplug power from PC.
2. Pull all memory from motherboard.
Replace one stick at a time and try to boot each time.
If the PC boots with one of the sticks, it may be the other that's bad.
3. Check the processor fan and heatsink. Make sure the fan is running. If your PC will boot after sitting for a while and cooling, this may be the cause.
4. You 'll need to have an open PCI-E, AGP or PCI slot to rule out the on-board video, if your mothrboard has this. Otherwise, you will have to remove the old video card and use one that you know works to rule out your current video card.
Hopefully one of these will help you solve your problem. Get back to me and let me know the outcome(s). It can be solved.
Make sure your computer is working properly. Hook up another known working monitor up to the computer and turn it on. If you get video on the known good monitor then that means the original monitor is bad. If you don't get video on the know good working monitor then that means the computer has no video output and the computer would need to be troubleshooted.
yes the remotes do have batteries. how ever that might be your problem or the remotes lost its code for programing. step when turning alarm off---- if its a factory alarm put the key in the drivers door when the door is closed and lock then unlock it thats the manuel shut down for factory. step 2------- aftermarket alarm. look for a valet switch most likely it would be installed by the driver kick panel or by the under dash fuse box. when u find it put the key into the ignition. turn it to the run position. within 3 seconds press and hold the valet switch for 3 to 5 seconds you should here a confirmation chirp and the led light will stay on solid and wont blink give it a world let me know what happens
If you are seeing an shadow image on the LCD and you have video on an external monitor, then the LCD backlight has failed. The LCD will need to be replaced
I googled B130 LCD's and they generally run $125 to $200
Product Details
function pw(s){pop('/xWI?lid=1&fid=1647&aid='+s)}
Product MPN
MPN
10K1912
Key Features
Form Factor
Desktop
Output Power (VA)
700 VA
Output Power (W)
425 W
Max Backup Time With Full Load
5 Minutes
Connectors
Total Number of Outputs
6 Outlets
Outlet Connectors
NEMA 5-15R
Technical Features
Recharge Time
4 Hours
Surge Suppression
With Surge Suppression
Automatic Shutdown
With Automatic Shutdown
Audible Alarm
With Audible Alarm
Cable Length
6 ft.
Dimensions
Width
4.75 in.
Depth
7 in.
Height
10.5 in.
Weight
20 lb.
Warranty
Warranty
2 Years
Miscellaneous
To set an alarm for an event:
1. Create a new event or double-click an existing event.
2. In the New/Edit Event dialog box, select the Alarm check box.
3. Click the time interval selector and select Minutes, Hours, or Days.
4. Type a number between 0 and 99 in the Time Measurement box.
5. Click OK.
To set a default alarm for all new events:
1. From the Tools menu, choose Options.
2. In the Options dialog box, click the Date Book tab.
3. Select the Alarm Preset check box.
4. Click the time interval selector and select Minutes, Hours, or Days.
5. Type a number between 0 and 99 in the Time Measurement box.
6. Click OK.
Setting Alarm Options
You can configure the Alarm Manager settings for the Desktop application in the Alarm tab of the Options dialog box.
To set Alarm options:
2. In the Options dialog box, click the Alarms tab and click one of the following actions:
* Always available: Click this option if you want alarm notifications to appear regardless of whether the Desktop application is running.
* Available only when Palm Desktop is running: Click this option if you want alarm notifications to appear only when the Desktop application is running.
* Disabled: Click this option if you do not want alarm notifications to appear on your computer.
3. If you want an alarm tone to sound when the alarm notification message appears, click Play audible notification with alarm dialog.
4. Click OK.
