Olympia CDP24200 Cordless Phone Logo
Posted on Sep 07, 2007
Cdp24201 base handset wont work
I have a trio of the olympia cdp24201 phones. All the phones work except for the base phone. The handset has suddenly stopped working. I can get a dial tone off the base intercom button but if I pick up the handset and try to get a dial tone its just dead. The handset says press C to search but if I do that it just keeps on searching and nothing ever happens. Any ideas?
  • Anonymous Dec 26, 2007
    Need yr svce center in Jakarta
  • thorwhite Jan 13, 2009
    after pressing "C" i get a request to enter the Bluetooth pin number. What is that?
Anonymous
Level 1:
  • Contributor 3 Answers
  • Posted on Sep 25, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
627
Points
If your interested folks I sell these phones and have small inventory left as well as the impossible to find blue tooth installation CD.
[email protected]
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Sep 09, 2007
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
185
Points
You just need to take the battery out and wait 30 seconds, replace it and it should be able to find the base. i had this problem and called olympia and this is the fix they gave me. It's worked for 4 years!
I cannot get my Panasonic base KX-TG5583 to register 8th handsets - only seven
It has to do with the electrical load that each ringer imposes on the line. Each set has a limit on how many handsets you can register with it. If you look on the bottom of the base you will see on the identification plate a data item called Ringer Equivalence Number or REN.
In telecommunication, a ringer equivalence number (REN) is a somewhat arbitrary number which denotes the electrical load a telephone ringer has on the line.
Cannot dial out when i call with my cell phone the phone rings but not on panasonic. phone says no link to base, move closer to base, still does not work
When my Panasonic goes stupid, I follow the instructions in the manual to re-register the handset. It involves the register command in the handset, pressing the handset locator on the base, then pressing O.K. on the handset and they find each other.
It seems to do this about 2 or 3 times a year, mostly after power failures.
Carl
Cordless phone not connecting to base. no dial tone.
switch the A/C mains off 5 minutes
or
Re-register them to the base,
This resolves the problem
Regards
Richard.
2answers
Olympia cdp24201
1. go to menu, then HS setting, then registration, register
2. follow the steps and register the set to the base.
3.press and hold the base mute button for 10 seconds, press next to continued
4.select the cbs and connect it.
5.enter 0000 as a password
The handset says SEARCHING for base......what do I need to do
That's usually a network problem brother, contact your service provider for free customer support. It could also mean that the unit may be having problems with its signal, like your out of coverage area.
GE MODEL 28112 DECT 6.0 CORDLESS PHONE
I contacted GE today and they told me how to get the caller ID to work on the additional handsets. You must follow these steps in the exact order given.
#1 - unplug the base phone
#2 - unplug the telephone line from the base phone
#3 - remove the battery packs from the phones
#4 - wait 10 minutes.
reverse the order when assembling. Put battery packs in phones, put the telephone line back in the base phone and lastly plug all phones back in. It takes about another 10 minutes after that before all phones start recognizing caller ID but it now works fine.
11helpful
Vtech M6896 phones do not work
Step 1: Press and hold FIND HANDSET on the main telephone base for 10 seconds.
Step 2: When the IN USE light starts to flash, release the FIND HANDSET button.
Step 3: Press and release FIND HANDSET again. The IN USE light will turn off and in a few seconds, all handsets will be de-registered.
Step 4: All handsets will show NOT REGISTERED.
To register a handset (register 1 handset at a time):
Step 1: Place the handset in the base unit or a charger that is connected to a power outlet. If PRESS FIND HNDST 4 SEC ON BASE does not appear on the screen after a few seconds, lift up handset and place in base or charger again.
Step 2: On the telephone base, press and hold FIND HANDSET for four seconds. Release FIND HANDSET once the IN USE light comes on.
After a while the handset will emit a series of tones, the newly registered handset will be assigned the lowest extension number not previously assigned to another system handset (1-4) when successfully registered. Repeat Steps 1 and 2 if the handset does not successfully register to the telephone base within two minutes.
No dial tone on handsets
Hey.. Did you check to see if the phone is registered correctly ???
Top Olympia Lands Phones Experts
k24674
Are you an Olympia Lands Phone Expert? Answer questions, earn points and help others
