More than likely your carburetors are gummed up with old fuel that turns to varnish after sitting for a long period of time without fuel stabilizer. You can easily test this by spraying a little quick start starting fluid into the carburetors and then try to start the motor. If it cranks up, for even a few seconds, then start by rebuilding the carburetors. If this solves your problem then I would recommend changing your water pump impeller as well.
Hello and welcome to FixYa!
As a first course of action, I strongly suggest that you
have the battery charged. It can be an indication of a weak battery or a faulty
alternator. If the battery light still on after charging then the problem will
surely be on the alternator itself. If that's the case the alternator should be
replaced to resolve the problem.
You may try to reset it to by removing the positive battery
connector, letting it sit for at least 5mins. then reconnect it again. This
will reset the system and can get the battery light off.
Hope this helps and thank you for using FixYa! Have a good one!
