Had my ac compressor replaced on my Jetta. Before I left the service/dealership, the windows (all 4) rolled down by themselves. Same thing when I stopped the car. Service says it's a computer body control module malfunction. They say there is no relationship to the repairs they did and when it started. What do you think?
Both are controlled via the Body Control Module so you make have a communication problem. If that is the case you need an auto electrician and a professional grade scan tool computer to check for diagnostic trouble codes DTCs.
Fuse or Relay Number
Fuse Rating
Protected Component
40A
Body control module - battery power in feed 1.
20A
Power outlet main console bin.
40A
Body control module - battery power in feed 2.
30A
Fuel pump.
5
5A
Powertrain control module keep alive power.
6
20A
Powertrain control module power.
7
20A
Canister vent solenoid. Evaporative leak control module. Exhaust gas heat recovery (hybrid electric vehicle). Tank pressure control valve (hybrid electric vehicle). Vapor blocking valve. Universal exhaust gas oxygen 11. Universal exhaust gas oxygen 21. Catalyst monitor sensor 12. Catalyst monitor sensor 22. Fuel flap door (hybrid electric vehicle).
8
20A
Cooling fan relay coil. Battery interrupt box. Transmission oil pump. Auxiliary coolant pump. Engine coolant bypass valve. Electric A/C compressor (hybrid electric vehicle). Active grille shutters.
9
20A
Ignition coils.
13
40A
Front blower motor relay.
14
15A
Transmission oil pump. A/C compressor variable clutch. Auxiliary pumps (hybrid electric vehicle). Electric A/C compressor (hybrid electric vehicle). Active grille shutters.
16
15A
Windshield and rear window washer pump relay power.
17
5A
Charge status indicator (hybrid electric vehicle).
18
30A
Starter motor.
21
10A
Headlamp red and blue flasher.
22
10A
Electric power assisted steering module.
23
10A
Anti-lock brake system module with integrated park brake.
24
10A
Powertrain control module. Hybrid powertrain control module.
25
10A
Air quality sensor. 360 camera with park aid. Rear view camera. Blind spot information system. Adaptive cruise control module.
26
15A
Transmission control module.
28
40A
Anti-lock brake system valves with integrated park brake.
29
60A
Anti-lock brake system pump with integrated park brake.
30
30A
Driver seat module.
31
30A
Passenger seat motor.
32
20A
Front media bin power point.
33
20A
Rear cargo area power point.
34
20A
Console end cap power point.
35
20A
36
40A
Power inverter.
38
30A
Climate controlled seat module.
41
30A
Power liftgate module.
42
30A
Trailer brake control module.
43
60A
Body control module.
44
10A
Brake on and off switch.
46
15A
Battery charger control module (hybrid electric vehicle).
50
40A
Heated backlite.
54
20A
Visor control module. Run/start access feed.
55
20A
Trailer tow park lamps.
57
30A
Trailer tow battery charge.
58
10A
Trailer tow backup lamps.
61
15A
Not used (spare).
62
15A
Headlamp washer pump.
64
40A
Four-wheel drive module.
69
30A
Front window wiper motor.
71
15A
Rear window wiper motor.
72
20A
Not used (spare).
73
30A
Driver door module.
78
Not used.
79
Not used.
80
20A
Not used (spare).
82
20A
Not used (spare).
88
20A
Rear blower motor.
91
20A
Trailer tow lighting module.
95
15A
Integrated spark control (hybrid electric vehicle).
96
15A
Not used (spare).
97
10A
Electric AC (hybrid electric vehicle). High voltage positive temperature coefficient heater (hybrid electric vehicle).
98
10A
Traction battery coolant proportional valve (hybrid electric vehicle).
103
50A
Rear power lug.
104
50A
Rear power lug.
105
40A
Not used (spare).
106
40A
B+ feed.
107
40A
B+ feed.
108
20A
Spot lamp.
109
30A
Passenger door module.
111
30A
Body control module voltage quality monitor feed.
112
20A
Not used (spare).
114
50A
Not used (spare).
115
20A
B+ feed.
116
5A
Start access circuit.
118
20A
Run/start feed.
120
15A
Port fuel injectors.
124
5A
Rain sensor.
125
5A
USB smart charger 1.
127
20A
B+ feed. Rear traffic advisor. Visor control module.
128
15A
Not used (spare).
131
Not used.
133
Not used.
134
10A
Delay accessory power.
136
20A
Not used (spare).
139
5A
USB smart charger 2.
142
5A
Traffic cam.
146
15A
Battery electronic control module.
148
30A
Left-hand headlamp module.
149
30A
Right-hand headlamp module.
150
40A
B+ feed.
155
25A
Transmission control module (hybrid electric vehicle).
159
15A
DC/DC converter (hybrid electric vehicle).
160
10A
B+ feed. Front warning lights. Strobes.
168
20A
Low voltage service disconnect.
169
10A
Coolant pump (hybrid electric vehicle).
170
10A
Traction battery coolant pump (hybrid electric vehicle). Pedestrian sounder (hybrid electric vehicle).
177
10A
Not used (spare).
Note: Spare fuse amperage may vary.
Passenger Compartment Fuse Panel
The fuse panel is under the instrument panel to the left of the steering column.
Note: It may be easier to access the fuse panel if you remove the finish trim piece.
Fuse Rating
Protected Component
Not used.
10A
Moonroof. Inverter. Telematics control unit module. Driver door switch pack.
7.5A
Memory seat switch. Wireless accessory charger module. Seat switches.
20A
Not used (spare).
5
Not used.
6
10A
Not used.
7
10A
Smart data link connector power.
8
5A
Telematics control unit module. Hands-free liftgate actuation module. Power liftgate module.
9
5A
Keypad switch. Rear climate control.
10
Not used.
11
Not used.
12
7.5A
Climate control head. Gear shift module.
13
7.5A
Steering column control module. Smart datalink connector. Instrument cluster.
14
15A
Not used (spare).
15
15A
SYNC. Integrated control panel.
16
Not used.
17
7.5A
Headlamp control module.
18
7.5A
Steering wheel interface.
19
5A
Headlamp switch.
20
5A
Ignition switch. Telematics control unit module. Key inhibit solenoid lock.
21
5A
Not used.
22
5A
Not used (spare).
23
30A
Not used (spare).
24
30A
Moonroof.
25
20A
Not used (spare).
26
30A
Not used (spare).
27
30A
Not used (spare).
28
30A
Not used (spare).
29
15A
Integrated computer screen.
30
5A
Brake switch signal.
31
10A
Terrain management switch. Selectable drive mode switch. Transceiver module.
32
20A
Audio control module.
33
Not used.
34
30A
Run/start relay.
35
5A
Low gear select.
36
15A
Park assist module. Image processing module A.
37
20A
Not used (spare).
38
30A
Left-hand rear power window. Right-hand rear power window.
An '87 Olds Toronado has three computers: the ECM (engine control module), the BCM (body control module), and the IPC ( instrument panel cluster). The A/C compressor is controlled by the body control module.
What Door Harness(s) did you replace? Why? List each function in Left Front Door that is not working. It is possible you damaged Left Front Door Harness. Are the other doors working fine? Disconnecting the Vehicle Battery is not necessary though it is safety step.
The power windows on your vehicle are controlled by an electronic control module , as are the power mirrors !
Power Window System Components
The power window system consists of the following components:
• Driver door module (DDM)
• Passenger door module (PDM)
• Body control module (BCM)
• LR power window switch
• RR power window switch
• Window up and window down relays in each of the rear passenger window switches
• Window lockout switch
• Reversible power window motors in each of the doors (circuit breaker protected)
• LT DOOR CB 25A (System power for left rear window)
• RT DOOR CB 25A (System power for right rear window)
Your best bet , take your vehicle to a qualified repair shop.
Happened to me several times in Florida, once in Canada. 1999 Chrysler Seabring Convertible Lxi 2.7. Computer locks out ignition for random periods. Took it to a Huge dealership in Florida, paid $350.00 for transmission shaft speed sensor stuff. Fixed it. Fine since. 1 yr. later body control module went (computer). Expensive to fix.$(800.00 just for dealer only part) Air door control, tachometer, and a rear window affected. I'll live with it as the 'failsafe' for loss of AC control is AC is 'Defrost/Floor'. Fan works fine.
Remove the battery negative cable for 5 minutes to reset the body control module and see if that corrects the problem. This can be a coincidence you know.
The body control module does not have anything to do with the windows.Depending on the year of your vehicle there is a drivers door module for the drivers and passengers side.What you should do is see if you are getting power to those switches that don`t work.Do they roll down with the drivers switch?If you post back make sure and include the year of your vehicle and I can look at the schematic for your windows.Good luck.
the heat controll failure is a stand alone issue, it needs replaced. As for the other issues, It sounds like the body controll module is malfunctioning, Only a dealer can test that module
