SOURCE: No TV audio coming from Sony DAV-HDX500.
If you are trying to make your TV audio come out your Sony system, you didn't say what the input to your TV was from (ex;Cable TV,Sat TV).
Sometimes it is easier to take the external (cable or Sat) out puts and feed the video into the TV but the red white into the AMP (TV input)then select TV on your AMP to hear TV.
Also some tv's need to make a speaker choice! go to Set up and change the speaker set up for the TV, you may have to tell the TV no speakers to create out put to Amp from the REd White TV out put.
SOURCE: sony c450 will not work with new 46" Samsung TV using compodent 3
are you sure that the channel your tv is on matches the name on the inputs where you plugged the component cables in? Channel surf-maybe start at 2 and go down and that is where those input channels should be.
SOURCE: CAN I HOOK THIS UP TO HD TV FEED WITH A PVR
henknm
If your PVR has an Optical Output then you will be able to hook that to your SONY DAV-S300. If it does not you will just be able to use the standard analog stereo connections. I included a picture of the Optical port on your SONY DAV-S300.
Issken
SOURCE: Sony DAV-C450 disc jammed. How can I remove them
your two options would be to remove the cover and disk tray and than remove the disk while nothing is in your way your other option would be to pry it open using a flathead screwdriver which could damage the tray motor and gears neither is suggested if the item is still under warranty or you lack general assembly skills
