If the message Replace Print Cartridge remains, it means that it is not the correct toner cartridge, replace it with the correct one. If Reset Print Cartridge message appears after correct replacement, it means that the toner cartridge is not set correctly or not installed. Set the toner cartridge correctly. If the cartridge is installed, close the front cover and turn the power switch to off and to on. If the message appears again, contact your sales or service representative.
On the upper right corner of the bin opening you will see a slot in the black plastic. I taped a part of a business card into the slot and it now works. Just make sure to unplug the machine when the door is open.
Unplug it and then open i t up. You are looking for a piece of shredded paper that is stuck or jammed. Can even be a accumulation of paper dust. The piece won't be that big but most of the time that is all that is wrong. The paper either jams the door sensor or blocks it and gives the error. It can also be a bad door sensor or switch. Not very common but can happen.
If you've got nothing my guess is its something more than the battery as it should still be able to draw power if its plugged in. If its within the warranty period (3 yrs, I believe). Go to the belkin webpage and to their ups support and start the process to return it and get it fixed/replaced. A couple months ago I had a F6C500-UNV that suddenly died on me just like yours - no nothing. It cost me $13.00 or so bucks to ship the broken unit to Belkin; a week or two later I got a brand spankin' new F6C550 or whatever they currently sell in that same voltage area back from them. The cost to RMA the broken unit was much cheaper than even buying a new battery for the old and now discontinued unit.
