SOURCE: where can I foind technical
what part are you wanting, water inlet is usually 3/8 npt, this unit can use 1/4 to 3/8 inch line
SOURCE: left the wash cycle on all night now ice machine
Cycle the drop door by pulling it open as if a load of ice just dropped
SOURCE: My franklin chef FIM200 is
Try putting a compression coupling in eliminating the valve. Did that on my machine a few months back, have not had any more leaks. Just other issues with thick ice and won't harvest correctly. Any suggestions?
SOURCE: I have a franklin chef fim400 ice maker that cycles but will not make ice. What could be wrong?
you may want to add shader valves using saddle type that just compresses on and check charge if low then find and repair leak and recharge but be careful these type ice machines are very touchy on charge so go slow
