Sony VAIO Notebook Logo
Anonymous Posted on Aug 21, 2013
Charge indicator is blinking fast and i can't power on may computer
Anonymous
Level 2:
  • Expert 159 Answers
  • Posted on Aug 21, 2013
Anonymous
Expert
Level 2:
Answers
159
Questions
0
Helped
42139
Points
410
Check ram, processor, if problem persists replace with a new ones
When ever I put on my battery on my dewalt charger the indicator light blinks faster than normal while charging
Possible reasons for this behavior:
Blinks Long (Red Light): If your battery is too hot, the charger will blink the red light rapidly and for an extended duration. To prevent this, ensure that your battery is not exposed to direct sunlight or excessive heat. Give it some rest to cool down.
Blinks Short: If the battery is too cold, it will blink short and fast. This could be due to prolonged exposure to cold temperatures or the battery being idle for an extended period. Allow the battery to charge for a while or bring it to room temperature to resolve this issue.
Blinks Very Fast (Doesn't Go Away): If the light is blinking very fast and persists, it indicates that your battery has gone bad and needs replacement.
2answers
Charger light blinks rapidly for dewalt charger?
usually indicates battery has failed slow blink charging steady red fully charged
Why does innotab charging light blink when charging and will not charge?
the charge imdicator is suppose to blink when you plug the toy to the wall adaptor. if it doesnt blink then there's something wrong with either the adaptor, the adaptor port on the toy or the rechargeable power packs. now i said that the light is suppose to blink. but the frequency of the blinks shouldnt be fast. if that's the case clean the compartments and re-insert the batteries. if you are still having problems try the ff T/S:
1)remove the power packs, plug the toy to adaptor and turn it on. if it turns on that means your adaptor is working.
2)remove the adaptor and try using just the power packs.
3)try using 4aa batteries.
if the toy turns on with only one of the power sources stated above you better call vtech hotline.
What does a orange power light mean
please see the commentary. God bless you
  • The majority of laptops will display a solid green, blue or purple battery light to indicate that the battery is fully charged. Most manufacturers indicate that a laptop is in the process of charging by displaying a solid or blinking green, orange, blue or purple light. If your battery indicator light is green, blue or purple, the battery is probably functional, regardless of whether the light is blinking. If the light is solid orange, the laptop is probably in the process of charging.
Battery Error Coneventions
  • Many battery manufacturers use rapidly blinking lights to indicate that a battery's charge level is low. In general, a laptop will rapidly blink orange or red when its charge drops below a certain level until the computer is plugged into a power outlet and charged. If your laptop's battery indicator continues to blink rapidly in orange or red or if it remains red even when it is plugged into the charger, it indicates a problem with your battery or the charger.
Read more: http://www.ehow.com/info_12183593_blinking-battery-light-laptop-mean-charger-not-charging.html#ixzz2fu5qhEWg
Zoostorm laptops
please read and execute the commentaries. God bless you
Charging Conventions
I can't power on my computer when i install the batterry pack and the charge indicator is blinking fast.
ok this is a battery fault.
try a differant battery.say of a friend same make.
see if it starts then.
5helpful
3answers
My laptop screen is black and caps lock and scroll key are flashing
That is a security configuration on HP Laptops, depending on the way they blink is the problem your machine has.
Here is the web page where this info is posted, in case you need more info, hope this helps you to determain.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01443366&lc=en&dlc=en&cc=uk&lang=en&rule=26781&product=3816592
This document pertains to HP Notebook PCs with the HP Unified Extensible Firmware Interface (UEFI) beginning in late-2008. On startup, you may see a blank screen. If the diagnostic utilities detect a specific problem with hardware components, the fan turns on, but the screen remains blank. To help identify the cause of the problem, various LED lights on the keyboard blink a series of codes. The diagnostic utilities use the LEDs near the Num Lock or Caps Lock keys to blink a series of error codes. At the end of the series the blinking stops. The pattern of blinks will occur any time you attempt to start the computer until the error is resolved. Battery power LED blinks The Battery power LED indicates the condition of the power supply. When starting the computer, or when the computer is in operation, use the chart to identify the power condition. Battery Power LED Component Tested Error Condition Battery power LED off, and Caps Lock/Num Lock off Battery or AC Adapter AC adapter not connected or failure
Battery low charge or failure Battery power LED blinking Battery Insufficient charge on the battery When new computer is used for first time, the white LED light for the AC power connector blinks. Battery is still in "Shipping Mode", the light continues to blink even when AC power is connected.
To resolve, turn off notebook, connect AC power and allow battery to charge for at least 30 minutes, then start computer. LEDs near Caps Lock and Number Lock keys blink when starting notebook The LED lights near the Caps Lock and Num Lock keys will blink if an error is detected during the start up process. The LEDs will blink a number of times in a sequence and then stop. The number of blinks in the sequence indicates what component caused an error when it was being tested during start up. If the LEDs stop blinking and the computer does not start, you can press the power button again to repeat the tests. Count the number of blinks, and use the chart to identify the error condition. Knowing the number of blinks is helpful when you contact an HP support agent for technical help. Caps Lock/Num Lock LED Component Tested Error Condition LEDs blink 1 time CPU CPU not functional LEDs blink 2 times BIOS BIOS corruption failure LEDs blink 3 times Memory Module error not functional LEDs blink 4 times Graphics Graphics controller not functional LEDs blink 5 times System board General system board failure LEDs blink 6 times BIOS BIOS authentication failure
1helpful
Battery indicator?
Hi there.
Sounds like the battery could be faulty.
The diagnostic procedures from the Dell User Guide are as follows:
Total Power Failure When Using a Battery
If an AC adapter is not connected to your computer, the computer's power source
is a battery. If the battery indicator flashes amber or is a steady amber, the
battery needs to be charged. If the battery is flashing green and amber, the
battery may be defective. To troubleshoot this problem, use the following
procedure.
1. Turn off the computer and peripherals, and disconnect them from AC power.
2. Reseat each installed battery by removing it and then replacing it.
3. Turn on the computer. Does the green power indicator light up?
Allow one minute for the computer to initialize its components before checking
for signs of power.
Yes. Continue to step 4.
No. Use the AC adapter to connect your computer to AC power. If the computer
operates normally when using AC power, go to step 7. If the computer does not
boot when using the AC adapter, see the previous subsection, "Total Power
Failure When Using the AC Adapter."
4. Does the battery indicator flash amber or show a a steady amber light?
Yes. The battery needs to be charged. Go step 5.
No. Go to step 7.
5. Connect the computer to AC power, and fully charge the battery.
For instructions, see the topic titled "Charging the Battery" in the online
System User's Guide.
6. As the battery charges, does the green battery indicator light up?
Yes. Go to step 9.
No. Go to step 7.
7. Is the battery indicator flashing green and amber?
Yes. Your computer may be in a hot environment. Charging the battery in this
condition may affect the life span of the battery. Continue to step 8.
No. The problem is resolved.
8. Disconnect the computer from AC power. Is the the battery indicator still
flashing amber?
Yes. You may have a defective battery. Continue to step 9.
9. Remove the battery, and press its test button. Is the uppermost indicator in
the charge gauge of the battery flashing?
Yes. You have a defective battery. Continue to step 9.
10. If a spare battery is available, fully charge it, and then install it in the
computer.
11. Turn on the computer. Is the power indicator off?
Yes. Your original battery is defective.
Good luck
2helpful
2answers
Rapidly flashing battery indicator light
From the user guide:-
Fast Blinking Amber:
Error in charging; check placement of the mobile computer.
Could be battery or changer problem.
If you need any more help then please do not hesitate to contact us:-
[email protected] or TEL 01202 620955
http://www.biastechnology.com/
Top Sony Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
