KitchenAid KESC307 Electric Kitchen Range Logo
Posted on Apr 08, 2009
Electric range broiler element popped and burnt
Amana electric range art6002w - broiler element popped and burnt; replaced but broiler does not work; bake element works and display clock and timer work. why would the new broiler element not work?
thanks
Anonymous
Level 1:
  • Contributor 2 Answers
  • Posted on Apr 09, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
1670
Points
8
Did you replace burnt fuse/tripped breaker?
I have an Amana stove model ART4002W. The oven will not heat above 250 degrees and the broiler element will not turn on. I replaced the broiler element and the heat sensor. No change.
if you have it on broil and the element doesn't heat up and you changed the element then you either have a loose or broken wire or a bad clock assy. part number 74009213 and it's around 166 dollars
I have an Amana ARDS802SS Electric Kitchen Range the broiler works but bake does not??
hello,
this means that there is disconnection on the element of the bake i.e heater (heat provider)
what it need is reconnection from the power supply.
And it could also be that the element is weak or bad which will need a replacement of a better one .
Good luck and thanks for using fixya.
2answers
Amana electric oven won't get above 225 degrees. Takes over an hour to get to this temp.
sounds like only the broiler is working which comes on low during bake cycle. unplug or turn off breaker, remove bake element and check for continuity or take to someone who can.
Kenmore range bake element doesn't work
check that the wiring is not bad and every thing is conected
Oven not lighting
That is not that hard to fix and you can easily buy the parts yourselfonline...
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
heatman101
2helpful
Broiler element broke and was burning as if it was being welded
Probably none. The sparking going on after you turned it off was probably the ground side of the element. Replace the element then re apply power and see if you have any trouble then.
Our Electric Amana Self Clean Oven, the broiler is not working? Help! The oven and stove top work just fine, but when we go to turn on the broiler the broiler doesn't come on, the selection buttons all...
canoyu physically inspect teh element for damage, perhaps its broken. or as wireleadingto the rearof elemnt has buntoff. you can check , but turn offpower first, the wires are always live
3helpful
FRIDGIDAIRE RANGE
It is most likely the pop came from a relay on the control board if the elements checked ok but not getting power to them. This is fairly common on fridgidaire ranges. Replace the oven control. Usually the control overlay is sold as a separate piece.
Top KitchenAid Kitchen Ranges Experts
vince
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
