John Deere Gilmour  Traveling Sprinkler - 4010j Logo
A
Anonymous Posted on Aug 20, 2013
Stripped worm drive gear. need replacement. - John Deere Gilmour Traveling Sprinkler - 4010j
Kitchenaid Mixer Planetary becomes sluggish when met with resistance.
The problem will be with the worm gear, if the gear is not stripped then check that the locating pin for the worm gear is not broken or missing. Occasionally the plastic gear can detach from the aluminium boss between plastic and shaft. The worm gear is the 99.9% place where drive can slip. Afterthought, I suppose the planetary pin is not missing or broken??
Mixer noisey and not going round freely
Your mixer most likely has a stripped gears, or a combination of stripped gears. The 5kpm5ewh is an international model similar to the ksm5. The gearing inside the mixer will be the same, some of the electrical parts may differ.
Your mixer has a nylon worm gear inside, this is the most common gear to strip inside the mixer. I would recommend opening the mixer and inspecting all of the gears before you place an order.
Most likely you will need the worm gear, which is available by itself (http://www.mendingshed.com/kawormgear.html) or you can get it in the whole worm drive pinion gear assembly (http://www.mendingshed.com/kitchenaidgearassy.html) the whole assembly is a lot easier to replace, and will save you a lot of time. You may also need to replace the grease inside your mixer, KitchenAid recommends the Benalene 930-2 food grade grease, it is only available in a 30oz can (http://www.mendingshed.com/kagrease.html) And you will also need to replace the gearbox gasket (http://www.mendingshed.com/mixergasket.html).
To aid you in your repair, here is a link to the KitchenAid service manual (http://lib.store.yahoo.net/lib/mendingshed/kitchenaidservicemanual.pdf) This will walk you through how to take apart the mixer, replace the gear, grease and gasket, and reassemble the mixer.
Thank you,
ColleenCustomer ServiceMendingShed.com800-339-9297
THE MENDING SHED, HELPING YOU GET THE JOB DONE SINCE 1971.
Removing worm follower gear in a Kitchenaid Professional 600 mixer
You need to drive the pin out with a punch. The pin should not be crimped on both ends, but could have been damaged if the gears stripped out.
Page 6 of the service manual walks you through removing the worm follower gear and dropping the planetary. Here is a link to the service manual: http://lib.store.yahoo.net/lib/mendingshed/kitchenaid6qtservicemanual.pdf
Thank you,
Colleen
Customer Service
MendingShed.com
800-339-9297
1helpful
Drive shaft spinning and it will not go into gear.
If you put your cycle in gear and the drive shaft spins, but the motorcycle does not move, you probably have stripped worm gears in the final drive housing. Take off the large fill cap on the side of the final drive housing and inspect the large gear visually. It is probably cheaper to buy a final drive assembly and replace the whole unit than to pay the labor and parts to rebuild it. ($700 for the 1100, $850 for the 650)
5helpful
Beaters won't turn bowl still does turn
I just took mine apart for this same issue. What i found was the plastic beater drive gears have been stripped by the motor worm gear. I am currently looking for these parts to replace them.
Plastic drive from the worm gear are stripped. I need to order new drive gears.
Here is a tip that will help you with the online buying...
How to Buy
Appliance Parts Online
heatman101
7helpful
Stripped gear on our Waring Pro FS150 Food Slicer
SmallAppliance.com has the part you need. Waring is no help at all. They only sell the replacement blade! Go to this web site: http://www.smallappliance.com/product.asp?pid=5147&cur=USD&cam=waring_parts&sid=18956&mid=34&gid=18971&prdCls=P&PartsPaNu=1&shopBy=Brand
and get the part. Thankfully they carry the motor gear you need. I had nothing but frustration dealing with Waring trying to get this part. Finally a nice Waring tech told me about smallappliance.com. Good Luck!
Top John Deere Garden Experts
john h
Sean Wright
Sean Wright
Jay Finke
Jay Finke
Are you a John Deere Garden Expert? Answer questions, earn points and help others
