Question about EliteGroup P4VMM2 Motherboard
I cant install hp laser jet 1018 on this board
I want to install printer hp 1018 laser jet but every time that turn the printer on the massage " the usb not recognize ... " has been shown... plz help me
  • 728 Answers
Hi h_kanani1366,
It doesn't sound like your problem is with the printer, it sounds like your problem is with the USB drivers for the motherboard. Look in Control Panel and click on System, then click on the Tab that's says Hardware, From there click on Hardware Devices, and when it opens look down on the Systems configuration area and look for a ! in a triangle. If you find one then the problem is the driver. You'll need to go to the manufacturer's site for that Motherboard and download a new USB controller driver, or sometimes there call Chipsets drivers. And that should fix your USB port, if the drivers aren't the problem, then could have a faulty motherboard. Try putting something else that you knows works into that same USB port to see if you get the same response. That will let you know if it's the motherboard, or it could be the Printer or the Cable that your using to connect to.
That's it my friend, there can be no other reasons I can think of.
Good Luck,and don't forget to leave a rating based on my solution.
Thanks Mark
Posted on Apr 09, 2009
Anonymous
SOURCE:
I dont have cd for laser jet 1018 printer instalation. how can i get software for this hardware?
you can download your drivers from here, you just need to choose the operating system you use, and download and install Product Installation Software
Hope this helps,
Lucas
Jul 07, 2011 | HP LaserJet 1018 Printer
I want to download driver hp laser jet 1018 so what i do
Use the link below.
HP LaserJet 1018 Printer - Download drivers and software
Download and install the driver first. Do not plug the USB cable until asked by the driver setup wizard.
Here more drivers for different brands:
I misplaced my printer driver disk.
How to download driver for a Canon printer...
How to install a Lexmark printer.
Apr 27, 2010 | HP LaserJet 1018 Printer
Can not install hp laser jet 1018 printer without cd
I dont know if you have or not but you could go to the hp websight and let them detect you printer and see if that will work.Hope this helps. Ken
Dec 09, 2009 | HP LaserJet 1018 Printer
Why won't the website www.iambored.co.za load but everything else loads just fine?
Laser Jet 1018 when print fade color out
Hi my name is Robinson from Ethiopia,Addis abeba my printer is laser jet 1018 i need to ask I am buy another cartilage new one and then install in my pc affter install the cartilage toner i see this things
1.when i print fade color out but the cartilage toner is new what is this problem i am guse may be paper quality or weather selection i am ask this one when some other place change the printer print pure with out fade may be guse more u tell me plz if u can now
Thank u!
Jun 25, 2009 | HP LaserJet 1018 Printer
Problem with hp laser jet 1018
i need the windows xp driver
Jul 12, 2008 | HP LaserJet 1018 Printer
Hp laser jet 1018 problem
try to connect the usb of your printer at the back usb ports of your CPU. and try to scan your device.
or
Do as follows inst.
Unplug your printer usb on your system. then attach it back to your computer then power on your printer.
Do right click my computer>properties> in system properties select hardware> then, click the Device Manager> tab, then select your device on PORTS. then click the scan for hardware changes> to scan your device. this icon can be found above or click Action menu and select >scan for hardware changes.
then restart PC. Hope you can do it. And it will help you.
thanks.
Jun 04, 2008 | HP LaserJet 1018 Printer
Hp laser Jet 1018
While printing A/4 size a bold doted line appear on the rigt side of the paper from top to bottom
Apr 17, 2008 | HP LaserJet 1018 Printer
HP laserjet 1018 service
Have you installed the new drivers for your HP?
Personally, on all HP Printers, I use only HP products, mainly Jetdirect Print Servers, but you might try creating a TCP Port Printer (via your Printer Install Wizard) and use that. You only need to know the IPAddress of the DLink and the Drivers for the HP Printer.
Dec 04, 2007 | D-Link DP 311U (DP-311U) Print Server
EliteGroup P4VMM2 Motherboard Logo
123 people viewed this question
Top EliteGroup Computers & Internet Experts
Thomas F. Schneider
Ekse
Tareq Bin Mostaq...
Tareq Bin Mostaq...
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
