SOURCE: Itunes library problem, itunes not opening
just uninstall the software and go to www.itunes.com and and download it. it automaticaly should download the one you need for your computer
SOURCE: itune library cannot be read because it was
The easiest solution is to close iTunes, delete or drag out iTunes Library.itl.
Start iTunes, then add your music folder.
SOURCE: The file "iTunes Library" cannot
iTunes.exe has been set to run in compatibility mode for an older
version of Windows. For best result, turn off compatibility mode of
iTunes before you open it.
> 1. Make sure iTunes isn't running.
2. Click Start, type regedit, then press Enter.
3. Navigate to this Registry location:HKEY_CURRENT_USER\Software\Microsoft\Windows NT\CurrentVersion\AppCompatFlags\Layers
4; Its better you clean/repair Windows registry with RegInOut.
4. Look in the main pane for a key that refers to iTunes. If you find one, delete it, then exit the Registry.
5. Start iTunes. The offending message should be gone!
