The diagram is not very good to see how the wires are arranged to use the spool gun for aluminum repairs. Can you help, a new diagram or somewhere I can see a decent picture? Thanks.
Clean and tighten connections both inside and outside unit.
Check and secure lead connections to remote control.
Be sure connection to work piece is clean and tight.
Remove excessive coils from weld cables.
If continues to be too high (hot) and can't control it, then you should send your machine to be checked that's probably a problem with the PC1 or PC2.
If this was useful to you please vote. Thank you and good luck.
