Question about Acer AOA150-1690 Aspire Notebook
Acer aspire 1690 laptop can't complete the booting process and restarts automatically. During the booting process, it shows XP windows but can not boot to the desktop and shows a blue screen but the message can't be read because it disappears within seconds of display and the system restarts automatically. Please, I need you help. Thanks
    Sergeant:
  • 305 Answers
Blue screen in XP is usually due to hardware issues. Did you add or change hardware? By now, probably your only solution is to repair windows XP by putting in the XP setup disk and get to repair. If you do the install, it will format your hard drive and you will lose your programs and files.
Posted on Nov 03, 2017
6ya staff
SOURCE:
Anonymous
  • 7 Answers
SOURCE: system crash
Acer Aspire One BIOS Recovery The AA1 has a built-in BIOS recovery routine, making it possible to flash the BIOS even if the system doesn't boot anymore. It's only meant for emergencies and may void your warranty, so use at your own risk.
Follow every step carefully!
First format an USB stick with FAT.
Download the latest BIOS, and put both FLASHIT.EXE and the BIOS file in the root directory of the stick. Rename the BIOS file to ZG5IA32.FD, that's important. Do not remove the USB stick.
Turn the AA1 off, make sure both battery and AC adapter are connected. Press Fn+Esc, keep it pressed and press the power button to turn the AA1 on. Release Fn+Esc after a few seconds, the power button will be blinking. Press the power button once. The AA1 will now initiate the BIOS flash, do not interrupt it under any circumstances. After a while the power button will stop blinking, and the AA1 will reboot shortly after. Wait patiently.
The BIOS has been flashed and all settings reset to default.
If for some reason you made a mistake during the procedure and it doesn't reboot by itself wait 5 minutes before turning it off, just to be safe that it isn't still flashing the BIOS.
Download WIN98BOOT.ZIP and HPUSBFORMATTER from the internet normal bootable like a dikette won't work with a usb stick
Posted on May 25, 2009
Anonymous
  • 31 Answers
SOURCE: Blank screen after boting up
There should be a display toggle key on your keyboard. This will toggle the display from the external display to the laptop lcd. Try pressing the Fn + F5 key to toggle the display.
Posted on Jun 10, 2009
leethedeuce
Lee A.
  • 4472 Answers
SOURCE: acer aspire 5570z wont boot to windows
Insert a windows boot disc. Go into the bios select it to boot from CD-ROM first. Then you can go from there. If you get it to boot to windows disc, then you could start reinstalling windows. If you are still having issues then there is a more serious issue. If you have any other questions let me know.
Thanks,
Lee
Posted on Aug 11, 2009
nanbuenbrazo
Reynante Buenbrazo
  • 553 Answers
SOURCE: No display in Acer aspire 4520g laptop
Have your laptop check up the technician, it has somethingt to do with your video card
Posted on Nov 05, 2009
Anonymous
  • 119 Answers
SOURCE: my acer aspire 5520 keeps shutting down on boot
Insert your restore CD if errors are found and not fixed by the checkdisk function listed above. Turn your computer off and then back on. You'll beasked to hit any button to boot from your CD; press any key. You will then beasked if you want to install a fresh version of your OS or "Repair" acurrent copy. Choose the "Repair" option.
Posted on Dec 24, 2009
How can I start up my Acer Aspire 5733-6410 in Safe Mode
Restart your laptop.
After it shows acer logo..Press F8 multiple times... (preferably 3 to 5 times)
a screen will show you multiple options.. Select Safe mode (this will be first option and then hit enter... It will show you your Window name (windows 7 / windows xp) press enter again and it will boot your window in safe mode
regards,
Bilal
May 31, 2014 | Acer Aspire 5600 Series 5630-6951 Laptop
Aspire 5710
During the boot process you will see on the screen to press a certain key to enter setup usually the Delete or the F2 key
Press and hold that key during the boot up process to enter BIOS the using arrow key scroll down to advanced bios features press enter change your first boot device to cd,press escape then press f10 to save to cmos to restart
note this will erase you operating system you will have to have an operating system disk to load it onto you hard drive or create a partition to load another operating system
(note after you have loaded the operating system you should go back and change the first boot device to your failsafe or optimized defaults)
after windows has loaded
your computer will automatically restart it might restart 2 times one to finish the installation
the next will be because the operating system is loaded and will boot from your cd
during the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS using the arrow keys load
failsafe defaults or load optimized defaults press escape then press f10 to save to cmos to restart
otherwise it will keep booting from the cd /dvd drive
hope this helps
Jul 26, 2012 | Acer Aspire 5710 Series Laptop Motherboard...
How to reformat acer aspire one d250
Press (right) ALT Gr+F10 before windows loading and the Acer logo is showing to enter the Acer Aspire's reformatting utility. Follow the on-screen prompts. Your laptop's hard drive will reformat and the original applications will be reinstalled. Your computer will restart after the reformatting process is complete. Enter your name and other personal information when prompted during the Windows operating system setup process.
Jul 01, 2011 | Computers & Internet
Aspire one notebook will not completely boot. It
While the system is booting --before the xp logo shows, hold down the F8 key. This will bring up a menu. Choose "start windows in safe mode with networking".
The os will start in safe mode. run a virus scan, defrag and scandisk, then restart the system. If is still wont boot normally, do the same thing then run a registry fixing program such as uniblue registrybooster, then reboot. If it still won't boot you may have to reinstall the OS. good luck.
PLEASE RATE THIS ADVICE WITH SOME THUMBS UP!!!
Apr 23, 2010 | Acer Aspire One PC Notebook
My acer aspire 5315 always show boot prepare os. When i want to install windows it cannot show cd boot (booting from cd/dvd) so i can't install windows. what is the solution sir? thank.
Restart you computer then hit F2 for Boot Bios Setting then GO TO Advance. Change the SATA Mode . ACHE. ot IDE. or Comfatibility.. then enable the F12 boot. make in enable. the hit F10 for save and exit...
Insert you cd os Installer then hit F12 for **** menu. select the CDROOM for boot....
Dec 30, 2009 | Acer Aspire 5315 Notebook
Windows instaling !!!
Have you waited for the remaining time?
If so, check your hardware compatibility.
Aug 26, 2009 | Acer Aspire 1690 Notebook
Acer Aspire 1690 cooling problem whit windows vista
Windows Vista is a very demanding Operating system when it comes to system resources and it doesnt come as a shock to hear that you computer runs warmly, If you werent experiencing any problems when you had windows XP installed, I would suggest downgrading to Window XP, otherwise wait for October 22 and purchase a genuine copy of Windows 7 and use that.
Jun 18, 2009 | Acer Aspire 1690 Notebook
Error Message : insufficient system resources exist to complete the API
boot your system in safe mode by pressing f8 key repeatedly during the booting process then select safe mode and press enter then go to system restore option, and select system restore, then select some previous date where system is working fine, restore it
how do you like the solution please rate it
Oct 12, 2008 | Acer Aspire 3680 Laptop
Acer Aspire 3680 bot issues
The problem is it is defaulting to lcd and not the external monitor
<FN><F5> to toggle to external
Jun 03, 2008 | Acer Aspire 3680 Laptop
Acer AOA150-1690 Aspire Notebook Logo
47 people viewed this question
Ekse
Alun Cox
Steve Sweetleaf
Steve Sweetleaf
