SOURCE: Dryer won't start when pushing the start button
bjsouth Most likely the problem with your dryer is bad motor. It is not repairable and has to be replaced. If you feel you can do it yourself, let me know and I'll help to buy new motor and provide you with instructions how to replace it. Gendos...post back
SOURCE: Dryer won't stay on
When you turn your start switch it gives temporary power to the motor and then centrifugal switch in the motor kicks in and gives power to the motor until the timer stops it or the door is opened.Your motor centrifugal switch could be bad due to poor contact or heavy linting in and around the motor.Vacuum inside the dryer specially around the motor. If it doesn't fix it you have to buy a new motor, centrifugal switch cannot be bought separately.
Sounds like the motor is cutting out on its thermal fuse. The only cure is to change the motor.
SOURCE: press the start button on dryer, it hums but wont
Sounds like a weak motor. You'll have to get a new motor installed. They are fairly inexpensive and easy to install yourself on that type of machine if you are handy. Motor is located in the bottom right of the machine, attached to the drum belt through a small pulley underneath the drum next to the motor.
SOURCE: DRYER WONT START
HELLO THERE:
The most common problems with this problem is that there is a fuse that has blown in the dryer or that the door switch has failed and needs to be replaced or the timer switvch or the motor it'sef has went out (NOT LIKLEY) THOUGH
Or THE dryers push start button is faulty
so please check these things out and replace any parts that are found to be defective
Hope this is very helpful for you best regards Mike
