SOURCE: My JVC LT-47X579 is not "turning on" since we
hmm i had the same problem the saturday before on my lt-42x579but i didnt have anything hooked up to it blue light came on then flashed ..no pic this happend one week after it was pd off from a rental store we should investigate
SOURCE: i have a jvc lt-26a6asj
hi,
the most probably is broken one of neon lamps that illuminates led display .you can check that when you turn it on and flashes, see if one side of screen is brighter then other.
also,it can be that power supply in led display got weakened and haven`t got enough power,but that is job for service like any bigger failure.
this is not the only answer,there is always several solutions but you have to give more informations about malfunctions.
good luck!
SOURCE: JVC LT-42X579 blinking blue light
wow thanks you thanks you God bless you who figured it out worked fabulously thanks again
SOURCE: jvc lt-42tg30j connecting to computer
Can you please follow guidelines given in the operation manuals of both?
SOURCE: blinking blu light on JVC LT-4TG30J
Its not making it out of standby, you could if can safely get it apart (ask if in doubt) inspect the power supply board for damage or puffed up filter caps, then consider having a shop look it over--All makers only sell circuit boards and no individual parts.
