Dell Latitude C610 Notebook Logo
Anonymous Posted on Aug 20, 2013
Drivers utilities cd diagnostic - Dell Latitude C610 Notebook
Anonymous
Level 1:
New Friend:
Problem Solver:
  • Contributor 9 Answers
  • Posted on Aug 20, 2013
Anonymous
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
9
Questions
0
Helped
403
Points
45
2 Related Answers
Anonymous
  • 171 Answers
  • Posted on Oct 14, 2009
SOURCE: No Diagnostic Utility Partition on dell vostro
You will find all the software and drivers for your Dell here.
If this helped you, then please help me and vote kindly. Thank you.
alanha
Axiom Media Support
  • 409 Answers
  • Posted on Sep 01, 2012
SOURCE: no diagnostic utility partition found to run diagnostics
Think about this for a min.
The Primary hard disk cannot be found by the System.
The Diagnostic Utility is ON the Primary hard disk.....OF COURSE IT WON'T FIND IT...
Since the motherboard is not able to even detect the drive as being present, there is nothing YOU can do to get it 'going' unless you replace the BAD hard drive with a new one.
[PS: I hope you've backed-up any important data....]
1helpful
No diagnostic utility partition found to run diagnostics
2helpful
Theres no sound on my dell inspiron 6000 and it said no device driver installed and so i downloaded the softwere from dell and i checked windows audio was turned on and updates and i even tried...
Try running diagnostics on your computer to seeif you have a hardware problem. You should have a CD that came with thecomputer that has "Diagnostics and Utilities" listed under contents.Boot form this CD and run the extended diagnostics.
If you don't have the CD you can go to www.support.dell.com andselect "Drivers and Downloads". Enter the "service tag" (serialnumber) of the computer. You can then download "Diagnostics" .
To boot from a CD disk, power on your computer and tap the key tobring you to the "One time boot menu". Insert the CD into the top CD/DVD driveand then select "Boot from CD/DVD" and hit key. Select the"Run the 32 Bit Dell Diagnostics.
1helpful
My Dell E 1505 DVD RW drive seems to record ok, but to play direct from a CD or DVD results in garbled sound, and degraded picture. Does this sound like a driver problem, or a hardware issue? (Playbacks...
This sounds like your DVD/CD drive is going bad. If it was a driver issue you would probably get an error of "no disk in drive".
If you have issues trying to boot form this CD or running the diagnostics then you CD/DVD drive needs to be replaced.
Dell Studio 1737 won't read cd/dvd's.
You should have a CD that came with the computerthat has "Diagnostics and Utilities" listed under contents. Boot formthis CD and run the extended diagnostics.
If you don't have the CD you can go to www.support.dell.com and select "Drivers and Downloads". Enter the"service tag" (serial number) of the computer. You can then download"Diagnostics" .
If you can't boot from the CD then you CD/DVD drive needs to be replaced. If the computer boots from the CD you have a software issue.
I accidentally uninstalled the driver to the cd burner, ho can i reinstall it?
You should have a CD that came with the computerthat has "Device Drivers" and "Diagnostics and Utilities" listed under contents.
If you don't have the CD you can go to www.support.dell.com andselect "Drivers and Downloads". Enter the "service tag" (serialnumber) of the computer. You can then download the driver for your CD/DVD.
As soon as I install the lan drivers on my gx280 it goes off and the cpu fan speeds up to full speed, without these drivers it would work fine all day without internet connection of course.
Try running diagnostics on yourcomputer to see if you have a hardware problem. You should have a CD that camewith the computer that has "Diagnostics and Utilities" listed undercontents. Boot form this CD and run the extended diagnostics.
If you don't have the CD you can go to www.support.dell.com and select "Drivers and Downloads". Enterthe "service tag" (serial number) of the computer. You can then download"Diagnostics" .
To boot from a CD disk, power on your computer and tap the key to bringyou to the "One time boot menu". Insert the CD into the top CD/DVD drive andthen select "Boot from CD/DVD" and hit key. Select the "Runthe 32 Bit Dell Diagnostics.
If all tests pass then reload OS ( Operating Software ).
Cannot read disk
"A disk read error occured press Ctrl+Alt+del to restart " FOLLOW THE BELOW INSTRUCTIONS TO RUN DELL DIAGNOSTIC ON INTERNAL HDD Open the Dell Diagnostics on either your hard drive (F12) or from the Resource (Drivers and Utilities) CD. Running from the hard drive is the preferred method of using the diagnostics. If problems occur when running from the hard drive or there is no Utility Partition, the diagnostics can be run from Resource (Drivers and Utility) CD. From your hard drive: Shut down and restart the computer. When the DELL® logo appears, press immediately. If you wait too long and the Microsoft® Windows® logo appears, continue to wait until you see the Windows desktop. Then shut down your computer and try again. When the boot device list appears, highlight ?Boot to Utility Partition? on desktop systems or ?Diagnostics? on portable systems and press . Note: On portable systems, PSA will be executed first. When PSA completes, press any key to load the Dell Diagnostics.? Go to step 2. NOTE: If you receive a message stating that no Diagnostics utility partition has been found, follow the instructions on the screen to run the Dell Diagnostics from your Resource (Drivers and Utilities) CD. From the Drivers and Utilities CD ResourceCD: Insert the Drivers and Utilities CD into the CD drive. Shut down and restart the computer. When the DELL® logo appears, press immediately. If you wait too long and the Microsoft® Windows® logo appears, continue to wait until you see the Windows desktop. Then shut down your computer and try again. NOTE: This feature changes the boot sequence for one time only. On the next start-up, the computer boots according to the devices specified in the system setup program. When the boot device list appears, highlight IDE CD-ROM and press . Select Boot from CD-ROM option from the CD boot menu. Select Run the 32 Bit Dell Diagnostics numbered list. If multiple versions are listed, select the version appropriate for your platform. Go to Step 2. After the Dell Diagnostics loads, the Main Menu appears. Click the button of the option you want. If a problem is encountered during a test, a message will display the error code and a description of the problem. Write down the error code and problem description and follow the instructions on the screen. If you can not resolve the error condition, contact Dell. If you run a test from the Custom Test or Symptom Tree option, click the tabs above the right window for more information: When the tests are completed, if you are running the Dell Diagnostics from the Drivers and Utilities CD, remove the Drivers and Utilities CD. Close the screen to return to the Main Menu screen. To exit the Dell Diagnostics and restart the computer, close the Main Menu screen. Regards Sunil Dsouza
3helpful
No Diagnostic Utility Partition on dell vostro 1400 need Dell "Drivers and Utilities" CD
Hey, My Dell Optiplex GX270 will run for a quick second, beep, and then a light with a barrel looking icon lights for a second too. How do I fix this? Thanks so much!
I would run diagnostics. Here's how you do it if the utility partition exists on your hard drive:
Starting the Dell Diagnostics From Your Hard Drive
  1. Shut down and restart the computer.
  2. When the DELL™ logo appears, press <F12> immediately.
NOTE: If you see a message stating that no diagnostics utility partition has been found, run the Dell Diagnostics from your Drivers and Utilities CD.
If you wait too long and the Microsoft® Windows® logo appears, continue to wait until you see the Windows desktop. Then shut down your computer through the Start menu and try again.
  1. When the boot device list appears, highlight Boot to Utility Partition and press <Enter>.
  2. When the Dell Diagnostics Main Menu appears, select the test you want to run.
2helpful
NEEED TO GO INTO CMOS SET EVERYTHING UP DATE THE HARD DRIVE , CD ROM, DVD, FLOPPIES DRIVES,HD DISK, HDS, CYCLDR, SETORS,
C-MOS BATTERY MAY NEED TO BE REPLACED,
ROD
DRIVERS
WWW.DELL.COM/DRIVERS
WWW.MOTHERBOARDS.ORG
WWW.MRDRIVERS.COM
WWW.DRIVERSHQ.COM
WWW.TOMSHARDWARE.COM
WWW.WINDRIVERS.COM
ROD
GO ON LINE AND TYPE THE FOLLOWING;
DELL LATITUDE D600 DRIVERS
OR
DELL INSPIRON 1150 DRIVERS
ENTER
ROD
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
