Kenmore 16.7 cu. ft. / 473 liter Upright Freezer 23724 Logo
A
Anonymous Posted on Aug 20, 2013
What's the age of my Kenmore freezer? - Kenmore 16.7 cu. ft. / 473 liter Upright Freezer 23724
1 Related Answer
Sal De
  • 2699 Answers
  • Posted on Jul 10, 2013
SOURCE: freezer age and kwh usage for kenmore 2722
go here,put the name,model and serial numbers in and it will tell you how old any appliance is.
http://www.appliance411.com/service/date-code.php
1helpful
Can a kenmore chest freezer model 253.16502101 also run as a fridge?
No, only a select few catering appliances can be a fridge or a freezer depending on the temperature setting. Yours is a freezer.
https://www.google.com/search?q=kenmore+chest+freezer+253.16502101+specs
I accidently turned off freezer.How do i turn it back on?
Turn the interior temperature control back on by setting at approx halfway between "off" and "coldest". (Make certain the branch circuit is hot - you should hear the compressor turn on when you set the control, possible an interior light will come on as well).
If the freezer does not run, check to see if you accidiently pulled the flash defrost plnger (if equipped). (See age 8 in your manual).
If you don't have a manual, you can download one here:
ShopYourWay KENMORE Upright Freezer ShopYourWay
(This is for Kenmore model 253.23024-101 or -102).
Freezer age and kwh usage for kenmore 2722
1helpful
My Kenmore Freezer, 5649215011, won't get cold
Yes it is. You probably have a bad capacitor since it probably as been outside for this long. It is subject to aging even when not in use. This should be an inexpensive job.
2answers
Capacity of Kenmore Freezer Model 253
I would like to know the capacity of my freezer
2helpful
Coil in top of freezer and top shelf in freezer have very large buildup of ice, melted it out but it soon froze back over
Good day,
I assume this is a conventional freezer, not a frost free model.
That condition is caused either by a loss of refrigerant or an internal restriction in the sealed system.
Both are, I'm afraid terminal, unless the machine is under 5 years of age, in which case it would be covered by factory warranty.
Can I plug my freezer into a surge protector
i know where your going and its a good thought
read your compressor, it will label the start up amp,
it may even be on the model label
it will give you the rated amps and the start up amps
this is current draw to run
as well as start up a stopped motor
depending on the age
most units use about
short of that use a 3x method
if it has the run amp x3 is startup
then read your surge protector if its rated higher than the amps needed to start the unit
then you should be fine
i will say most SP are rated at 15amps
my freezer is rated at 18amperes
When plugged, it shorts the surge protector and outlets.
I noticed that my refrigerator, kenmore freezer2_bing.gif, and stove were all not on. This has not ever been a problem before, so I unplugged the surge protector and reset the outlet. I then plugged the refrigerator2_bing.gif and the kenmore freezer to the surge protector and I noticed when I plugged the kenmore freezer it just shorted the surge protector. I then just plugged in the refrigerator and oven to the surge protector with no problems. I tried to plug kenmore freezer to other outlet and same result "a short
2answers
Kenmore chest freezer power problem
Try to unplug the the unit power supply to reset the error. But if the error persist you have to call for a qualified technician,
Top Kenmore Freezers Experts
Jay Finke
Jay Finke
ZJ Limited
ZJ Limited
Are you a Kenmore Freezer Expert? Answer questions, earn points and help others
