SOURCE: night mode off
Does the Main Phone, usually the Receptionist have a button labeled RTO ( Ring Plan Overide ) ? If it does then this button can be used to change the ringing destination. If the button is on the Reception phone then press the RTO key, enter Password ( 0 0 0 0 ), 2 ( assuming ring plan 2 is Day mode ),then hang up. If this totally messes up your ringing then cancel the above by pressing the RTO again, enter password ( 0 0 0 0 ), 0. Let me know how it goes, the phone system type is what I was asking for and it should be marked back in the phone closet where all the phones are connected. Talk to you later
SOURCE: How to change the voice mail message on KP DCS - 24B LCD samsung
I have the manual for the DCS series and there is no help regarding this.
It does say how to turn from auto to manual and make sure that the time is correct.
1. If the manual NIGHT key is pressed BEFORE the system automatically enters night service then the automatic night service timer tables will be overriden until the system is manually restored to day mode.
2. If AFTER the system automatically enters the night service tables and will not be overriden.
SOURCE: How do I change the date & time on our Samsung
Please follow the steps :-
1) Press transfer.
2) Dial 800.
3) Enter passcode = (try 4321 or 1234)
4) Press 1.
5) Press the speaker button.
6) Dial 505.
7) The display will show.
WMMDDYY:00:00
w=day of the week (1=Mon. - 7=Sun.)
mm=2 digit month
dd= 2 digit day
yy=2 digit year
time must be entered in military time when done press Transfer.
I hope I was able to help you.
SOURCE: We use the Samsung 12
Hi, To enter voicemail, press the Voice Message Key, the pass code will be set in default to 0000. Your mailbox will not function properly until you have put your voice message on. To do this, press option 0, followed by 5 followed by 7. When you have got the message you require press the #. If you regularly change your voicemail message, you must press 3, delete the original message and reset the message followed by the #.
watch the following video, or go to http://www.abbeytelecom.com for a written version, I hope this helps ">
