Once the date has been stamped on the photo, it's there just like the subject's face or the overflowing trashcan in the background or whatever. You can edit the photo somewhat using a photo editing program, using the same process as deleting any other object in your photo.
You can go to MENU > Setup > Date Stamp to turn it off. Or you can go to MENU > Setup > Time to reset the correct time.
By the way, if you want to edit your photos after taking photos, you can use Leawo PhotoIns. This software is designed as an all-featured photo editor which consists of 2 main modules, including Photo Enhancer and Photo BG Remover.
Photo Enhancer is a professional and AI-powered photo enhancer to improve your photo quality in batch. It can automatically and intelligently analyzes and perfects your photos with AI technology, including face enhancement, color enhancement, lens correction and more.
Photo BG Remover is a professional and one-stop photo background remover to automatically remove background from image. It can intelligently analyze the clipping edges, precisely enclose the region to cut out elements, and magically remove photo background. Besides, it also supports manual adjustment to remove photo background more precisely.
SOURCE: i have kodak Easy Share
In any mode, press the MENU button. Use up/down to highlight Setup (three horizontal sliders) and press OK. Use up/down to highlight "Date Stamp" and press OK. Make your choice and press OK.
SOURCE: How i can remove the
Press the MENU button. Use left/right to select Setup, then up/down to select "Date Stamp".
SOURCE: kodak easy share camerac 613
The date and time (and a lot more) are stored with every picture in its EXIF metadata. Any photo viewing/editing program should be able to display this data. To print this data, please consult the documentation for whatever program you're using to print your pictures. Depending on the program and printer you may print the date and/or time on the image, in the margins, or on the back.
Turn the Kodak's dial to "Capture" mode. This brings up the camera display. Press the "Program" button behind the dial.
Press the "Down" button until "Date Stamp" is highlighted. Press the "OK" or "Set" button to access the date-stamp menu.
Press the "Down" button to change the selection to "None." This removes the date stamp.
Press "OK" to save the setting. Press "Program" to return to capture mode.
