SOURCE: Lost of space on micro SD card
Yes you can get your space back.
Let me clear you first you lost the space due to while system is writing data in your SD micro card it is suddenly ejected or disabled.
You will do this method to retrieve you data back. You will need some things
1. Card reader for SD micro memory.
2. A software called D M comes as Hard disk tool it comes in bootable cds.
You will remove your H D for safe side to protect your hard disk data.
Put your SD card in card reader and start you computer with bootable cd that contains D M software.
When your system is boot from cd run D M and go to option in D M erase all data. This will retrieve your all space from SD. Remember you can do the same thing with Hard disk if there is any bad sector or some space not avalible or disk partion is not able to delete by any softwares.
Hope this will help you, If you have any problem regards this you can reply to me other wise don't forget to make ansewer my thread.
Regards
nidostyle
SOURCE: How to Create EISA Partition...in Vista Or XP......
You can't. The partition was created by SONY to hold recovery files because so many people lose their installation disks. So SONY created the partition, loaded the special software on it and put options in the menu to use it.
SOURCE: SD Card wiped is wiped out, crashes camera?
go to the following site and download the SD card format software. Format the SD card again. it should work. http://www.sdcard.org/consumers/formatter/
