You either have something caught in the blower or you have a bad motor. If you unplug the dryer and pull it out. Then remove the rear panel (1/4" hex screws), looking at it from the rear, the blower is on your left. Remove the two screws that hold the blower housing on. You should be able to get your hand in far enough to see if there is something in the blower.
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
