Posted on Apr 08, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The subwoofer sound is very low with the bose acousticmass 5 III
I have the older model Bose acousticmass 5 II home theater system and I have never gotten the subwoofer to actually put out much sound. You almost have to put your ear in the hole to hear it. I have never hooked up an amp or anything. When I use my receiver to set surrpound sound up it is saying that I dont even have a subwoofer hooked up and when I run a tone test it does not play any sound at all.
Anonymous
Level 2:
Scholar:
  • Expert 45 Answers
  • Posted on Apr 09, 2009
Anonymous
Expert
Level 2:
Scholar:
Answers
45
Questions
0
Helped
29089
Points
103
Chewi5,
There is a saying in the audio industry I've come accustomed to hearing -
"No high's, no lows, it must be Bose" Anyway that is just a reference to the flat sounding nature of Bose in general and some people like the accuracy Bose is trying to deliver. I believe your problem is not related to this heavily opinionated statement. The fact that you have a very low sound coming from the sub is an indication that the RCA cables may be hooked up to an input rather than an output. I know this from my own experience and, if this is your problem you are in luck. Just find the proper output and the problem is fixed. The test tones and message also reinforce my main theory. However if this is not solved by my first suggestion you may have to start checking your audio cables for continuity. A bad ground (or even out of phase preamp signals) on an RCA cable can also produce similar symptoms. Let me know if none of this helped and I will try suggesting something more in depth & technical.
-Dynami
1helpful
How do I test the Bose ps28 3 sub woofer without any other bose components?
Thats a toughie because that system is well..a system. They build those so that each component runs through that main circuit board there and then thru the outs on the sub--I would look for a used player that you can hook it up to or pass on it.
Can the bose mini remote for cinemate II be used with older cinemate version?
Mostly it'll work if it's Same CineMate Series. Other Models like Bose Companion won't work.
Need to replace pigtail fuse
This may not be a fuse. Bose uses devices like this as "speaker protection". If this device is wired to the woofer, that is exactly what it is. For more information, please visit my website at audioserviceclinic.com. Thank you.
3helpful
Same problem here. It's all been working perfectly well for about 5 years. Not all I get is sound, but no picture from DVDs. Have tried changing round all the wires and experimenting, but still can't get a...
I just had this issue with my bose 321 and fixed by resetting the system - unplug the cable from unit and subwoofer for 1 minute, plug it back in and voila, it worked. Saved me a trip to bose store! :) Good luck.
1helpful
I have a Lifestyle 35 and want to replace head unit with a 5.1 receiver. The Bose subwoofer model LSPS uses a network type cable connector on the sub side and a male din plug on the head unit side of...
The entire 5.1 amplification system, in the Bose Lifestyle 35, is actually part of the Bose Acoustimass (subwoofer) module. The RJ-45 (network type) connector passes a low-voltage signal from the console to the Acoustimass module. If you were to hack the connection, and plug the speaker outputs of a 5.1 receiver to the RJ-45 socket on the Acoustimass module, you would blow the amplifier.
If you are really itching to replace the Bose Lifestyle 35 console with a regular 5.1 receiver, I strongly suggest you sell your Bose system, and purchase a Bose speaker system, such as the Acoustimass 10 Home Theater Speaker System, which is made for use with a standard 5.1 surround sound receiver.
14helpful
2answers
Is there a current model receiver that I can puchase to drive my existing subwoofer and 5 speaker set? My Series 5 died.
How to connect Bose Acoustimass 25 series II subwoofer to Denon Receiver using factory provided 13pin cable
Bose lifestile 5 sound from the right speaker exit only
may be problem in the main unit change the IC or check the cable inside the main unit
 Grubhead
Grubhead
SmartAviator
SmartAviator
