Cars & Trucks Logo
Anonymous Posted on Aug 19, 2013
Gears marks - Pickup Mitsubishi Cars & Trucks
william youngman
Level 1:
New Friend:
  • Contributor 18 Answers
  • Posted on Aug 19, 2013
william youngman
Contributor
Level 1:
New Friend:
Answers
18
Questions
Helped
3338
Points
42
What gears are you talking about if it is the timing belt put the no 6 or no 4 piston on top dead center rockers are rocking and the mark on the harmonick balancer shows marks on top dead center and the over head cam has a mark on it to lines up with a mark on the timing cover mark.
Need to know how to set the timing marks for the camshaft gear & crankshaft gear
I would say that you line the marks up together between the gears. One gear should have two mars and the other gear should have one mark put the one mark between the two marks
1helpful
How do you adjust valves on a 2006 3.5L V6 Toyota Avalon?
There is a Toyota Technical Service Bulletin issued for this:-
T-SB-0291-08 September 11, 2008 2GR-FE Valve Timing
Procedure Service Category Engine/Hybrid System Section Engine Mechanical Market USA Applicability YEAR(S) MODEL(S) ADDITIONAL INFORMATION 2005 - 2009 Avalon 2007 - 2009 Camry VDS(s): BK46K 2008 - 2009 Highlander 2006 - 2009 RAV4 Engine(s): 2GR VDS(s): BK31V, BK32V, BK33V, BK34V, ZK31V, ZK32V, ZK33V, ZK34V, ZK35V 2007 - 2009 Sienna Introduction This service bulletin provides information regarding valve timing inspection and service guidelines for vehicles equipped with 2GR-FE engines. © 2008 Toyota Motor Sales, USA Page 1 of 5 T-SB-0291-08 September 11, 2008 Page 2 of 5 2GR-FE Valve Timing Procedure Introduction (Continued) Figure 1. 3 2 1 5 9 8 7 6 4 1 RH Bank Intake Camshaft Timing Gear 2 RH Bank Exhaust Camshaft Timing Gear 3 RH Bank No. 2 Timing Chain 4 Crankshaft 5 Idler Gear 6 Timing Chain 7 LH Bank No. 2 Timing Chain 8 LH Bank Exhaust Camshaft Timing Gear 9 LH Bank Intake Camshaft Timing Gear Warranty Information OP CODE DESCRIPTION TIME OFP T1 T2 N/A Not Applicable to Warranty © 2008 Toyota Motor Sales, USA T-SB-0291-08 September 11, 2008 Page 3 of 5 2GR-FE Valve Timing Procedure Inspection 1. Set the No. 1 cylinder to TDC/compression. A. Set the timing mark to 0 on the timing chain cover by rotating the crankshaft clockwise. B. Verify the timing marks on the camshaft timing gears are in general alignment with the timing marks of the camshaft bearing cap: TIMING MARK IDENTIFICATION CYLINDER BANK INTAKE GEAR MARK EXHAUST GEAR MARK RH Bank (Bank 1) Small Mark Single Line LH Bank (Bank 2) Large Mark Double Line HINT When the engine is correctly timed, the timing marks will NOT perfectly align. Figure 2. Figure 3. RH Bank Exhaust Camshaft Timing Gear 1 2 1 Bearing Cap Timing Mark 2 Gear Timing Mark Figure 4. RH Bank Intake Camshaft Timing Gear 2 1 1 Bearing Cap Timing Mark 2 Gear Timing Mark © 2008 Toyota Motor Sales, USA T-SB-0291-08 September 11, 2008 Page 4 of 5 2GR-FE Valve Timing Procedure Inspection (Continued) Figure 5. LH Bank Intake Camshaft Timing Gear 1 2 1 Bearing Cap Timing Mark 2 Gear Timing Mark Figure 6. LH Bank Exhaust Camshaft Timing Gear 1 2 1 Bearing Cap Timing Mark 2 Gear Timing Mark HINT If the timing marks appear vastly out of alignment, turn the crankshaft one revolution (360 ) clockwise and note the position of the timing marks. Component Removal Guidelines 1. If engine disassembly is required that involves removing the camshafts or timing gears, set the #1 cylinder to TDC compression, wipe away any oil, and mark the following items in relation to each other prior to disassembly: • Timing gears • Timing chain • Timing chain No. 2 NOTE This relationship MUST be maintained. The intake gear is timed in relation to the crankshaft via the timing chain; the exhaust gear is timed in relation to the intake gear via the No. 2 timing chain. © 2008 Toyota Motor Sales, USA T-SB-0291-08 September 11, 2008 Page 5 of 5 2GR-FE Valve Timing Procedure Component Removal Guidelines (Continued) 2. If NEW camshaft timing gears or the No. 2 timing chain are being installed, the two yellow links on the No. 2 timing chain can be used to ensure correct relationship between the intake timing gear and the exhaust timing gear. Figure 7. 1 1 Yellow Link A. Align the paint mark on the timing chain with the intake gear timing mark (to ensure the intake gear is correctly timed to the crankshaft). Figure 8. RH Bank and LH Bank 3 3 4 3 3 4 5 4 5 4 1 2 1 RH Bank 2 LH Bank 3 Yellow Link 4 Gear Timing Mark 5 Timing Chain Paint Mark B. Align the two yellow links on the No. 2 timing chain to the timing marks on
Saab 2006 1.9 tid cambelt timing marks
these bend valves if belt breaks while running
Align the timing marks on the camshaft gears to the notches on the camshaft cover, using the intake gear mark for the intake gear and the exhaust gear mark for the exhaust gear.
Align the mark on the crankshaft gear with the
notch at the bottom of the rear timing belt cover.
1helpful
How do I find the timing marks to time a 4-cyl 93 Caravan engine? I have the crank gear and camshaft gear already exposed and new belt already on. I need to know how to align it to the proper position.
The crankshaft gear has a center punch mark on gear and the intermediate gear has a line mark on gear. Rotate the crank until the #1 piston is top dead center. In doing so the crankshaft mark should line up with the intermediate gear mark. (crankshaft mark at 1 oclock and intermediate gear mark at 7 oclock). At the same time look at the cam gear and the small hole should be at the top and the two larger holes should align with the bearing cap. ((parting line should be looking at it will be 50/50 when you look at the front of cam gear). Remember to remove belt before timing engine correctly. Also make sure the negative wire is disconnected from battery before starting this job. Hope this will help you.
I am putting a new timing belt on a 1990 colt vista with a 2.0 liter engine.I need to know the timing mark positions.
On cam gear there's a punch mark, line that mark at 9 oclock there's a timing mark on cylinder head, crank gear, in back of crank gear is a plate with a (v) cut line gear at 11 oclock there's a timing mark on front case, gear to right of crank gear has a (v) cut on it, line it at about 11 oclock at timing mark on front case, adj tensioner and your done.Good Luck.
How to set timming belt,cant find mark for crankshaft 3.0L
Timing belt removed, static timing was not set before removing timing belt.
[Set Static Timing:
No.1 piston is brought up to TDC before removing timing belt.
Cam gear has a punchmark on face of gear, and this mark aligns with one single tooth. There is a matching punchmark on the Timing Belt Rear Upper Cover.
Facing the cam gear, the mark is to the upper right. There is an 'egg shape' of the timing belt upper rear cover, in this spot. This punchmark is in that 'egg shape', and is close to a bolt hole. The cam gear mark lines up with the Timing Belt Rear Upper Cover, mark.
The crankshaft gear has a punchmark on the face. It lines up with one single tooth. There is a corresponding punchmark on the lower right side. An alignment mark)
Should be a round punchmark on the face of the crankshaft gear. It lines up with a single tooth. Wipe the gear clean, use a little carb cleaner. (NO flames, or sparks nearby, well ventilated area)
Barring you cannot find the crankshaft mark, find the camshaft alignment marks, make sure they are aligned with the alignment, (Punchmark), on the Timing Upper Rear Cover.
Count the teeth in the timing belt. There should be 133 teeth on the belt.
There is 43 teeth in-between the timing mark of the camshaft, and the timing mark on the crankshaft.
(43 teeth in-between the Right Side Camshaft mark to crankshaft mark, 43 teeth in-between the Left Side Camshaft mark to crankshaft mark)
There should be 40 teeth in-between the two cam gears.
Timing Belt Markings
Mark are on the crank and cam timing gears. Cam gear mark at 12 o"clock crank gear mark lined up with TGC mark on block when installing timing belt.
Settings to replace cam belt
There should be marks stamped into the cam and crank gears that need to line up with corresponding marks on the backing plate before you remove the cambelt.
If there are no markings, you need to make your own.
Rotate crank until at TDC (reinstall the crank drivebelt pulley loosely and front cover to do this, then take them off again)
Once at TDC, use correction fluid and mark the crank position twice - once on the crank gear itself and a corresponding mark on the backing plate.
Ditto for the cam gear.
Make sure these marks are aligned when cambelt is replaced, turn engine one full revolution when new cambelt is on to double check marks line up where they should and you're good to go.
Sometimes the cam isn't marked but the crank gear is. In that case line up the crank gear and use the above step to mark the cam gear.
Be precise as the cam gear will most likely move when you take the cambelt off due to tension from the cam on the rockers
Hope this helps :)
Top Mitsubishi Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
john h
Are you a Mitsubishi Expert? Answer questions, earn points and help others
