How do you remove the back of a Timberland watch to replace the battery?? The back of the watch has 6 little grooves evenly spaced, which would indicate the back should turn/screw off rather than be prized off.
SOURCE: replace the back of a dkny watch after replacing the battery,
For closing your caseback you need the man with very strong hands first, but it might not work as some casebacks can be closed using special tools only.
Before you visit the watchmaker, try this: first of all open your bracelet by taking out spring lug. This will make more space at the back. Then take watch caseback and check for groove in it. Align that groove with stem (pin going into watch movement) and deepen grooved caseback side as it should be. Then without turning caseback apply great pressure with both hands to the watch(from caseback and dial sides). If hands are strong enough, caseback should snap on into place.
In case if it doesn't work, find a piece of thick leather (wide mens belt will do) and place it on completely flat surface (table top). Place the watch face down on that leather, adjust caseback groove with stem again and try to press caseback down with both hands, only this time using your weight.
If all mentioned above doesn't work- you have to go to see watchmaker.
Good luck.
Arthur
SOURCE: what to do with watch repair kit
Unless the watch back has notches on it, you want to look around the edge of the watch and find a little lip. When you find the lipp, use one of the knives and pry open the back. Take one of the tweezers and pull out the battery, you could also use one of those handy-dandy screwdrivers to pry out the battery. Put the new battery in laying exactly like the old one , then proceed to close the back, making sure that the little notch (on the INSIDE lip of the back case) lines up with the stem and crown (the part used for setting the watch) so not to break it. The back openers and the knives are just differant ways to opn the back of the watch. Sometimes watches have screws on the back that need to be taken off in order to open the back case. The case vise is to minumize the wear and tear on your hands. The tweezers are for taking out the battery. If you have anymore questions PLEASE feel free to contact me I will be glad to assist you further! Good Luck!!!
SOURCE: technomarine watch battery replacement
If you plan on doing this yourself, find a nice heavy pair of needle nose pliers and put the ends in the knotches on the casing back. Have them as far apart from each other as you can and turn counter-clockwise. If you still have problems opening, put the watch in a vise with the lugs in the teeth of the vise. DO NOT tighten too hard or you will snap the lugs. It dosn't have to be tight , just enough to hold the watch while you turn the back. If you still have problems please let me know and we will find another way of doing this.Good luck!!
SOURCE: Kenneth Cole Watch KC3493... getting the back off
sometimes watches must be opened from the crystal side
SOURCE: removing the back to change battery
The plastic wrist band doesn't have to be cut away. You need to dislodge the spring-loaded end of the pin from the hole in the plastic with the blade of a sharp thin knife.
The you proceed to lift one of the 4 snaps to open the cover. The battery is under a white translucent inside cover.
The original battery was Sony SR621SW.
Pay attention to the rubber seal ring when putting the watch back together.
