Hey i have an old Clark fork-truck hydraulic model CY20B it has both side shift and the forks can spread out and contract where the forks are there is two hydraulic cylinders with two connections each (1 cylinder per fork) and there is a manifold with 6 connections on it i need to know which hoses go where
So if you have three cylinders then the extend ports of the cylinders(bottom) should go to the 'A side of the valve and the Rod end or retract (top) should go to the "b" side. The A or B are probably not marked. Each cylinder should go to the valve at the coresponding lever.
Hope this helps you ask again for more..WF Services
Is it the valve that has 6 wave manifold? or is it a double stacked vavle and is it a tilt fork with the forks operated with rams?
