SOURCE: I have a craftsmen 18 volt drill. Will it be hurt if I use a 19.
You should never provide more voltage to a tool or motor than what it is designed for. So, as a result, I would advise strongly against it. You have the chance of frying circuits and capacitors very easily by doing so.
On the flip side, using too low a voltage will also result in motor damage. Stick with an 18v battery for an 18v drill.
If you are happy with this answer, please rate this response on FixYa.
SOURCE: delta 18 volt charger broken
buy a new one
Testimonial: "you missed the point te charger is "obsolete""
SOURCE: Does anyone know if you can substitute the 18 volt
Look at eReplacementParts.com and the parts diagrams.
If you need more help come back.Post / thumbs / testimonial are welcome!
SOURCE: I have an 18 volt
No. It will probably charge but you will significantly reduce the life of your battery.
