SOURCE: CPu fan turns for 1 second and then stops.
If all was working fine before, then, you have either not connected the cpu power cable, as is sometimes required other than being powered by the processor socket, or your power supply unit is not pentium 4 compatable and is unable to power the processor.
SOURCE: atx12v1 cable
The repeating single beep with a small pause (actually 3 Beeps a Pause) clearly indicates problems with RAM .Replace it ,your problem will be solved . As for connecting the 12 volt 4 pin connector all mobos are designed to sense the presence of this 12 volts and ONLY THEN TURN ON.
SOURCE: No Signal To my Monitor and no beep.
First refix the RAM and Pci graphic card.
Pull cmos cell from mother bord for 15 minutes then put again into its position then all settings are defaults.
Then if still face problem then check with other RAM.
Testimonial: "kamal is the man!!"
SOURCE: Packard Bell IMedia 5055: GA-8SIML will not post
Put just the ram back into the motherboard, the pc will not boot without processor, ram and graphics pluged into the board, check this, if it will still not boot and you still get 3 beeps its a memory(ram) problem, and you will need to replace the memory stick.
SOURCE: I've got a new Gigabyte
Most motherboards now have a 24-pin power supply connector. If you haven't already found a diagram showing the pinouts of the 20- and 24-pin power plugs, here's one borrowed from a handy site:
The two plugs are essentially the same, but the 24-pin version duplicates some voltages on the extra pins. The extra pins in the larger connector were meant to provide extra current paths for voltages that see heavy loads from newer processors and motherboard circuitry. Depending on how a motherboard is designed, it might work with a 20-pin plug connected (leaving pins 11, 12, 23 and 24 empty). But typically if the board has a 24-pin connector it needs the 24-pin power supply plug.
Most power supplies have a 20-pin plug with a separate 4-pin section that fastens to it for connection to a 24-pin mobo connector. It typically has one side designed to slide onto the end of the 20-pin plug, essentially turning it into the 24-pin version. This added plug does not have a retaining clamp on its side, so you can tell it from the the 4-pin CPU power plug. The wire colors are also different. For reference, here is the processor power plug, from the same website:
New motherboard specs call for the separate processor power connector for the same reason the extra pins were added to the power supply connector: to handle the high currents needed by increasingly faster CPUs.
When the motherboard has these connectors, you need to use them all to get everything working. Hope this helps. Thanks to smspowersupply.com for the diagrams, and thank you for using Fixya.
Testimonial: "Thanx - cleared up the confusion about P1. Additional tests are pointing to a d.o.a. motherboard."
