I removed the h.d.d cable, power led, reset sw, dc sw cable and speaker cable. My processor is intel pentium 2 and it is written executive computers (ecl). It is a desktop and i have forgoten how the mention cables where connected.
Http://www.youtube.com/watch?v=HZ5w3ZUC_5k
DOES THIS HELP ?.
SOURCE: Connection
=1024) && (screen.height>=768))
document.write( 'Search
manual, information?
Part number
Manual
Warranty information
Refund information
Rebate information
Serial numbers / manufacturer numbers
Billing information
Missing or lost CD, disk, or install file
Upgrade information
Part Number
There are literally millions if not billions of different part numbers used by companies today. Because of the vast quantity of part numbers and the frequency of those numbers getting changed or referenced to other numbers, Computer Hope is unable to offer its customers with third-party part numbers.
If you are looking for a part number we recommend that you contact the computer company or the company responsible for supporting your product. You can find a listing of companies and their contact information on our company listing.
If the company responsible for your product is no longer in business we recommend the below.
Also see: Part Number (PN) Computer Hope dictionary definition.
Manual
suggest you visit the manufacturer of your product web page.
Also see: Manual Computer Hope dictionary definition
Serial Numbers
Unfortunately, with the billions of different serial numbers and manufacturer numbers, contact the manufacturer of the product or look for information about the product on Computer Hope by searching by the manufacturer or type of device name. For example, instead of searching for "Serial Number 12345" it may be easier to search for "Maxtor hard drive".
If you are looking for a serial number for a particular software program you will need to contact the software developer or producer of the software program; Computer Hope will not provide any type of serial numbers or other registration numbers to any users. See our underground section for additional information to why Computer Hope does not provide this information.
Finally, a serial number for a hardware device such as a computer or printer can almost always be found on the bottom or back of the device. If you're trying to find the serial number for one of these devices try physically examining the device. If you're still having issues locating it the contact the manufacturer .
If you've lost one or more of your installation CD's or diskettes you must contact the developer of that program to obtain a new copy. Computer Hope cannot send anyone copies of the disks or downloadable files over the Internet of the program regardless if you have purchased the program.
SOURCE: reset/power/led etc..lead connections
to,
davewhisner
you have to specify your model no of mother board & brand also full code than i will saw you how to connect that ports with figured out,
THNX
SOURCE: a GeForce7050M-M (V2.0)computer motherboard front
You may have the pins reversed.
Good Luck.
SOURCE: MY COMPUTER WONT TURN ON !!!
for connecting these sw
just see on mother board there you see nearabout 16 pins on right hand bottem of mother board
there you have an integation of connectorfrom right hand corner i.e 1-3 for reset sw, 2-4 for power sw and last switches for front usb and audio
if you have p-3 then you dont attech audio and usb cables on *********** board
SOURCE: I put a motherboard in my pc and i dont know where
http://eu.shuttle.com/archive/en/prod/mb/big/av49vn.jpg
ok man on this picture in the bottom of the pic there will be a sort of black rectangle with nine pins, 5 on bottom, four on top. This is where all your POWER SW,RESET SW,HDD LED,POWER LED will be plugged in. I could not find instructions for your board but for mine it is
Looking at the pins from the side where there are 5 pins on the bottom and 4 on top. The top two sould be the power led the two next to that should be the power switch, the bottom two to the left should be the hard drive led and the two next to that should be reset.
This is not the guaranteed position seeing as we have two completely different models.
Hope this helps.
