Troubleshooting
Error codes
An icon or error code will appear on the LCD screen if any of the following happen:
The cover of the Safety Release Knob is open. Close the cover and the footrest massage will resume.
The footrest massage unit is not in operation position or retract position.
Extend the footrest massage unit by pressing the recline button
and the footrest massage function will resume.
LCD returns
to 'Main Menu'
The backrest bottom panel is being depressed by some obstacle. Remove the obstacle and re-start the program.
Error 15 mean it has overheated.
google has an answer perhaps in below link
https://www.google.com/search?q=Osaki+massage+chair+has+error+code+20&oq=Osaki+massage+chair+has+error+code+20&aqs=chrome..69i57&sourceid=chrome&ie=UTF-8
Step 1 open drive where data is save after it open your company data folder than you have find a file (TMESSAGE.TSF) it's error code 0 select this file and deleted its after above process 100% your problem solve out
roblem : The machine displays an E674 code. This may be followed by an E677 code when the Fax pcb is removed. The imageRunner also has a Print Board installed.
Solution :
With the Fax Board and Print Board installed an E674 code occurred. When the Fax Board was removed an E677 code then occurred. Try removing the PDL Interface pcb for the Print Board from the copier. Reinstall the Fax Board, if the E674 code does not occur and the copier is capable of sending and receiving faxes, then replace the PDL Interface pcb because it may be faulty and causing the two E codes; E674 for faxing and E677 for printing.
E42 means scanner error. It's posible to be dirt scanner timing sensor or the whell. You can check videos on youtube to find how can fix this issue in detailed mode.
677 error is printer board error.u check conection( lpt port or usb cable loose conection.printer board loose conection.remove all conection and conect all conection i mean reinsert conection ) then this error come u will service u r printer board(re insolve printer softwere).803 error is expouser lamp end side blocked change u r lamp u r 803 problem is ok
