SOURCE: Lenovo IdeaPad Y530 - 40512SU
Ensure that you did not press the conbination of keys that switches to the external screen, on thinkpads this is Function key , plus one of the numbers.
Check if the computer is in sleep (hybernate) mode, in this case you should be able to wake it up with the start button, or on some model with the wake up button.
IF you still cannto restart the computer, then it is probably frozen, remove battery and try to restart the laptop in this way.
After restarting check the power settings (you find them also on display properties/screensaver, or in the control panel). set the computer not to turn off.
If the computer screen does not turn on again doing the above, or there is no way to wake it up when it goes in standby, then the unit may be faulty.
If the computer is new, in this case, better getting a replacement or a repair.
Green means you have a full battery charge.
So probably it seems your battery is out of juice. Keep it on charges & it should be fine.
If there is nothing changed, you may need to exchange the laptop charger.
Lenovo IdeaPad Z570 AC Adapter
Hope this helps.
