My HP color laserjet 4500 started to print blank pages in the middle of a print job. After that, other print jobs produced only blank pages. I replace the transfer kit but that did not fix the problem.
This is usually the Transfer kit, but if the image drum or one of the power supplies goes bad, that can also give blank pages. The Drum problem for no print is usually a grounding/connection problem. Power Supplies are a complicated repair, but these printers aren't too bad to work on. You can buy good used one's fairly cheap on ebay, though. Should consider going to a later model CLJ if you replace with a used, though.
