SOURCE: Error message: Service error 5100 on my new Canon MP160 Printer
Error Code.........Description
5000 ...................Home position error
5100 ...................Carriage control error
5200 ...................Head temperature sensor error
5400 ...................Printer temperature sensor error
5600 ...................No cartridge error
5C00 ...................Purging operation error
5200 ...................Scanner cartridge error
As a technician, I have worked on tons of printers. This particular error had stumped me for a while, but I finally found the cause. As others had pointed out before, it can have alot to do with some obstruction in the print path, the gears, or ink on the clear plastic encoder strip. You're on the right track - I found the the purge cap (the white sliding mechanism that the print head parks to when it's not in use) was not lubricated well enough from factory. If you lubricate the sliders with some white grease (don't get it on the small wipers or the black caps) the mechanism can now slide more freely, and the unit can park the head properly without giving you the dreaded head homing error 5100 (or E-2-2 on the LCD display) Keep in mind that this repair will probably require you to remove the right panel off of the printer to gain access to the purge mechanism. There are two screws behind the printer, and two in front for each corrosponding side panel (the front screws are behind the grey front panel of the printer - open the top cover to see the clips which hold the front cover on) Hope this helps some of you out.
good luck (^_^)
SOURCE: error message inner cover is open canon pixma mp610 printer
Had the same problem myself but discovered that I had previously moved the inside flap down when I put the ink in. I moved this back into position and bingo! (If you make sure all the covers are closed then look into the printer where the paper exits you will see the flap that moves up and down, this must be in the up position)
SOURCE: the ink cartridge cannot recognized (refilled 3 times)
i am having canon pixma ip1300 inkjet printer. it worked properly till 13th april 09 i got refilled both cartridge and fix it in my printer but the cartridge was not recognized. i had tried installing the cartridge many times and also tried switch off and on it again many times but the printer shows the same error that "An error occurred.Some ink cartridges cannot be recognized." and a message box is opened and it shows that "An ink cartridge is not installed properly.Open the printer's cover, make sure the ink cartridge is installed properly, and close the cover." help me to recover from this problem i can't afford to buy new cartridges. suggest me some ideas and procedures to make my printer work again. give me the remedy as quickly as possible Thank you
SOURCE: Canon Pixma ip1900 Printer wont print
i think you need a canon resetter just download it and it will fix your problem. gud luck ellyhill
SOURCE: I have purchased a
Hi there you can try.
Following step by step resetting canon Pixma iP90 :
All I ask is please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
