ViewSonic E70fb 17" CRT Monitor Logo
Anonymous Posted on Aug 17, 2013
Memory lock error - ViewSonic E70fb 17" CRT Monitor
Bob Sloan
Level 3:
  • ViewSonic Master 2,013 Answers
  • Posted on May 30, 2014
Bob Sloan
ViewSonic Master
Level 3:
Answers
2013
Questions
Helped
356904
Points
8519
If you mean the OSD lock, see the manual here...
http://www.manualslib.com/manual/186478/Viewsonic-E70fb.html
1helpful
Why do I see MEMORY STICK ERROR on my Sony camcorder?
Check the memory stick for a little slide lock on the side. Make sure that is not in the locked position. This feature is there to prevent people from recording over special memories, like weddings. But sometimes during handling (or just not knowing) people accidentally switch it to "lock"
Good luck
tip
Laptop LED Blink on Startup There are many reasons that a computer does not...
There are many reasons that a computer does not startup or boot into the Windows operating system. If your computer will not start or boot, you will see or hear symptom to indicate the general area of the problem.
Startup Symptom: LEDs blink but does not start
The blinking LED lights on newer computers, or the beep tones on older computers, will help support agent determine what hardware component is not responding properly. The exact meaning of each code varies with the model, and the user cannot change any of the blink or beep codes.
DO THESE FIRST - Perform a hard reset.
If a PC suddenly fails to boot properly, you should perform a hard reset as the first procedure.
1. Disconnect all peripheral devices and remove all USB devices and media cards. You want to test the computer not the accessories!
2. Disconnect the AC power adapter, remove the battery and then press and hold the power button for at least 15 seconds.
3. Reconnect the AC power adapter (but do not connect the battery), Press the Power button, Look for glowing LEDs near caps lock and num lock keys, and Listen for sounds of a disk drive and fan turning.
Identify the number of blinks or beeps
When there is a start-up problem and you see LED lights on the keyboard blink a few times (between 1 and 8 blinks) do the following actions.
Table of Sample Blink Codes
The following table illustrates the meaning of blink codes used on some notebooks. The blink or beep codes on your computer may have different meanings.
Meaning of Sample Blink Codes for some EFI Notebooks:
1) Number of Blink: Continuous Glow, Blinking LED: Battery power LED, Component: Battery,
Error Condition: The AC adapter is attached and the battery is charging, but does not yet have sufficient charge to power the notebook.
2) Number of Blink: 1, Blinking LED: Caps Lock/Num Lock, Component: CPU,
Error Condition: CPU not functional
3) Number of Blink: 2, Blinking LED: Caps Lock/Num Lock, Component: BIOS,
Error Condition: BIOS corruption failure
4) Number of Blink: 3, Blinking LED: Caps Lock/Num Lock, Component: Memory,
Error Condition: Module error not functional
5) Number of Blink: 4, Blinking LED: Caps Lock/Num Lock, Component: Graphics,
Error Condition: Graphics controller not functional.
6) Number of Blink: 5, Blinking LED: Caps Lock/Num Lock, Component: system board,
Error Condition: General system board failure.
7) Number of Blink: 6, Blinking LED: Caps Lock/Num Lock, Component: BIOS,
Error Condition: BIOS authentication failure.
8) Number of Blink: Continuous blink, Blinking LED: AC power adapter LED, Component: Power adapter,
Error Condition: Insufficient power
Common solutions for issues that cause blinking LEDs or beep tones
When the computer can boot into the BIOS, run the memory test to identify other issues.
Check for loose connections and test the memory
Blink codes are often displayed after a user adds memory to the computer but does not seat the module properly. The LEDs may also blink error codes if a hardware component is loose because the computer was dropped or jarred. The problem could be that the stick of memory or one of the memory slots has a bad connection.
Check for loose memory modules
If a memory module is loose or is not making good contact with the memory slots, the computer does not recognize all of the memory. Reseating the memory module may resolve memory failure errors.
on Mar 21, 2011 • Computers & Internet
tip
Memory Card Locked / write protected error.
Hi due to so many questions asked about this here it is. How to deal with memory card locked/write protected error.
SOLUTION 1 - Unlock the memory card.
There is a Lock switch on the left side of the SD card. Make sure the Lock switch is slid up (unlock position). You will not be able to modify or delete the contents on the memory card if it is locked.
SOLUTION 2 - Toggle the lock switch.
If the lock switch is not on lock:
1. Slide the switch up and down. Repeat this 3 times.
2. Let it stay on the Lock position for 30 seconds.
3. Slide the switch up to unlock the card.
4. Try to transfer files into the device.
For non-SD cards: Format the card
The data on the memory card may be corrupted.
WARNING: Formatting will delete all the files in the device. Backup all your data before formatting.
Memory card write protected, memory card locked, memory card will not read, can't use memory card.
My sandisk memory stick pro duo has shown up file error in my pictures so when i go to transfer them on to my computer it can't get past the error how do i solve this?
Without knowing what the specific error is this is my best guess:
1helpful
2answers
My canon camera keeps displaying 'memory card' error and 'memory locked', what do I do?
check you sd card there is lock and unlock switch. unlock that button
Display says memory card error card locked
Format memory card by using card reader, then try it.
4helpful
Memory card error
Did you format the card in the camera before trying to use it?
2helpful
Memory card is locked
SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
2answers
Canon Camera - Memory Card error & Card locked error
Try reading the card independent of a camera i.e. on a computer or a photo kiosk to determine if the card is readable damaged
3helpful
2answers
Memory card error displayed
There is a little slide switch on the side of the memory card. Good luck!
Top ViewSonic Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Rob Hill
Rob Hill
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
