SOURCE: de walt de9118 charger
when charger is plug in to ac it will blink once.normal voltage out for the unit in between 36v to 55 volt. the reading u have is normal.
SOURCE: Diagram for rebuilding DeWalt DC988
Yes.
Go to dewaltservicenet.com and look up your model. (Hint: Press the "Go" button on the screen not the Enter button on your keyboard to submit your model in the field). Make sure you have your type number available.
If your transmission is in a million pieces I can help you get it back together. There is no diagram for the transmissions.
SOURCE: can't engage drill or hammer settings on de walt dc 925 xrp
Try turning the ring to 2 or 3 and run the drill holding the chuck so the clutch slips then try turning it to drill setting. Also try to do it in different speed settings. If not it sounds like a fault in the gear module. It might just be a metal clip just under the clip in side. Undo the 4 screws holding the gearbox onto the housing and carefully remove it, you might see the fault or loads of dirt that needs cleaning. Go to http://www.2helpu.com/world/map.aspx for a drawing.
