SOURCE: Printer brother DCP330 Problem
You may encounter a paper jam while working with your Brother printer. You need to be cautious while feeding the paper to your printer. Paper jams are often obvious, but you might come across a situation when you do not get any indication that the paper has jammed up the printer. In such cases, you need to open your printer and visually inspect it to search for the jammed paper. If the rollers of your printer are leaving marks on the printouts, then there is a need to clean them. Using chemical cleaners such as benzine, thinner, or alcohol to clean the rollers might prove hazardous to your printer.
SOURCE: nu reusesc sa instalez imprimanta
Here is a link to daownload driver, just select operating system.
http://welcome.solutions.brother.com/bsc/public/eu/gb/en/dlf/download_top.html?reg=eu&c=gb&lang=en&prod=dcp135c_eu_as
