I lost my manuel for Kodak EasyShare Z1285 Digital Camera. Now I can't transfer pictures to my computer. Help!
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo management program such as Picasa.
Organize edit and share your photos
You may download the Z1285 User Guide at http://resources.kodak.com/support/pdf/en/manuals/urg00732/Z1275_Z1285_UG_GLB_en.pdf and the Z1285 Extended User Guide at http://resources.kodak.com/support/pdf/en/manuals/urg00731/Z1275_Z1285_XUG_GLB_en.pdf
SOURCE: transferring pictures from my Kodak EasyShare digital camera to my computer
This error message means that the preferences in EasyShare software are set to save pictures to the CD-ROM drive or some drive other than your hard drive. To correct this, follow these steps: Start EasyShare software. Select Tools > Preferences. Select the Transfer tab. Below "Select the location on your hard disk where you want to copy transferred pictures," select Browse. Browse to the desired location on the hard drive where you want to transfer your pictures. The default location is: For Windows 98/Me Operating Systems: c:/My Documents/My Pictures/Kodak Pictures For Windows 2000/XP Operating Systems: c:/Documents and Settings/user name/My Documents/My Pictures/Kodak Pictures Select OK to return to Preferences, then click Apply and OK to save and close the Preferences. Reconnect the camera, and transfer the pictures.
SOURCE: "The device is not ready"
SOURCE: I have a Kodak Easyshare C530 how do I transfer pictures from computer to camera?
hey, yes you can transfer pictures from the computer to your camera...you take the memory card from your camera and insert it in your computer (if you do not have the slot to insert the memory card you cannot transfer pictures) thn sync pictures to the memory card and then insert memory card back into camera.
SOURCE: No power to my new Kodak - Series 3 EasyShare Dock for Select Kodak EasyShare Digital Cameras
Hey ditzydiana,
If you just purchased the camera and you are already having problems with it I would not try to troubleshoot the problem I would exchange it for a new one. If you purchased the camera from a Best Buy™ store the return/exchange period on the camera is 14 days. I hope this helps!
Sincerely,
Allan
Go Ahead. Use Us.
SOURCE: Kodak EasyShare digital camera
is a way to do this. take out your mmc card of what a card you have and put it in card reader, then conenct with copmuter , ciopy your image files to the directory that you have in the card for pictures, if not known where put it directly in the card without directory, then take your card again put it in your digi camera and enjoy seeing your pictures.
