SOURCE: Epson stylus photo 1290 printing black splodges
Joy:
Once more have the printer to perform the ink nozzles cleaning.
If you are using a ontinuos ink system, place it at the same level than that of the printer.
With the printer in the "replace carrtidge position", put it OFF and by hand, clean the place at which the cartridge rest.
Good luck and merry christmas
emiliosan
SOURCE: Epson Stylus C67 keeps printing blank pages
The symptoms infer that the problem is with the computer (printing from an application) rather than the printer (prints OK when the computer is not involved). The best way out of this is to uninstall the printer (start-control panel-uninstall software-epson software). But before you do this double-click the printer icon in the printer list (start-control panel-printers & faxes) and cancel all print jobs in the list (if there are any). Then uninstall the printer Then reboot the computer. Make sure your printer is connected to the computer BUT TURNED OFF. Then insert your printer installation CD and re-install the printer. Turn on the printer when prompted. All should then be well.
SOURCE: Epson Stylus Photo R300 sounds like it's printing
I know there are some cleaning cartridges with a chemical thinner that could clean any ink residual that could interfere with proper function of the printing head.
If this doesn't work you probably have to replace the head.
Check also the flat cable that follows the printing head during movement.
Fabio
SOURCE: EPSON Stylus SX600FW printer. Recently changed
Did you use Epson Genuine Cartridges?
ALL…. Epson & Brother Requires Genuine Epson Cartridges. !!!!!!!!
That sounds like your problem.
In Purchasing Epson's CX 5400, CX4600, & CX7400 and more, I found out that Epson does not like Generic Printer Cartridges. I also Purchased a Brother. That also does not like Generic Print Cartridges. Color that should be Yellow, will turn out Green, Blue Brown, etc. These printers have a CHIP that will detect if it is Generic or Genuine. When they see it’s Generic Cartridges, it will print lines thru the words, stripes across the picture and also do a mix match with the colors.
That's what these Companies do., so they can keep selling the ink cartridges. Some Printers, are able to use Generic, and some are refillable. Some you can refill them up yourself and I heard, quite MESSY.
So I learned, thru trial and error, that you must use the ORIGINAL Genuine Cartridges for these PRINTERS. Some people say some models work fine compatible, but not mine.......
I had to replace the printer, but Epson, Lexmark & Brothers are always on sale. My Brother & Epson cost me $50.00 with Rebate. Don’t waste too much ink in cleaning it.
This is the only advice I can give you. If you find this helpful, pls rate me.
Thanks and Good Luck :0)
SOURCE: Paper Feed on EPSON STYLUS SX115
go reclaim to the epson service agent or where you purchase.
Note: take all ink cardriges out. they dont need them.
Compatible Systems: Windows 7 32-bit, Windows 7 64-bit, Windows Vista 32-bit, Windows Vista 64-bit, Windows XP 32-bit, Windows XP 64-bit
View all downloads for Windows 7 64-bit in the sections below, or select a different operating system above to reveal other downloads for your product
