SOURCE: Changing announcement on Avaya Partner ACS phone
Selector code 3 is playing an announcement. You have to go into programming, press selector code 3. depending on the voiceail yu have....you may be able to modify it right there.. Other wise you willl have to find the annuoncements.
If you repost with what voicemail model it is, i can tell you exactly.
SOURCE: Avaya 18D Change Number of Rings
Programming is done on extension 10 or 11
Press feature 00
Left intercom, Left intercom
#506
mode 1
line 01
number of rings 4
do the same for all lines
Cheers
SOURCE: programming auto attendant on partner II
The extensions in the voicemail group are not programmed. You need to put the ports that the system sees the voicemail, into #505, group 7.
