Epson Perfection 2450 Photo Flatbed Scanner Logo
Posted on Apr 07, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Epson 2450 Perfection Photo Scanner Have only used this scanner for 4x5 trans film and have lost the 120 and 35mm holders. Can 35mm neg strips be scanned without film holder? Any problems with placing negs directly on glass scanner bed. Mark
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jul 20, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
652
Points
The Epson film holders hold the film 1 mm (.039") above the glass scanning window. You could cut and glue 1 mm plastic sheets to make your own holder if you can't get the originals from Epson. I'm making one now that will hold more than a single frame of 120 film, which is all the original Epson holder would take.
Anonymous
Level 3:
  • Master 526 Answers
  • Posted on Dec 02, 2009
Anonymous
Master
Level 3:
Answers
526
Questions
0
Helped
264304
Points
1566
Its a lot more accurate if you have the holders, you can run into problems. you can order the part from epson or
an epson service center like us.
thanks adi
2helpful
How do I clean the underside of the glass on the 2450 epson perfection scanner?
Scanners are not meant to be user serviceable. This means that to clean the inside of the scanner, its better that it be brought to the manufacturer who can do this in a safe and correct manner. Believe me, it is worth doing this than ending up having a non-working scanner.
2helpful
2answers
No driver for epson perfection 2450 vista 64bit
From Epson FAQ:
Q: Does Epson have Microsoft Vista 64-bit drivers available for my scanner? A: Currently, we do not have Microsoft Vista 64-bit drivers available for your scanner. However, you may be able to use the VueScansoftware from Hamrick; it supports Microsoft Vista 64-bit. Please visit the Hamrick web site for more information.
http://www.hamrick.com/vsm.html
Not tried it yet as I don't have 64 bit installed (my research is in preperation)...
1helpful
Loading negative film in holder.
The button under the top door is for ejecting the film strip. To load negatives you just insert them until the machine recognizes them and then it will automatically load them.
I have a 3490 scanner but have lost the neg holder to scan negs.
You really cannot scan a neg without a special holder. I recommend paying $90 to Costco and buying their special USB Scanner which scans one neg at atime! They are great!
Thanks,
Mark
Slide scanning with Epson Perfection 2450
I don't know if this is truly a "solution" or not, but I get the same thing on my HP 4850 scans. After scanning, I just crop the pictures to remove the black borders. Can you do that?
3helpful
Epson perfection 4990 photo scanner
Please do the following to scan slides or negatives in manual mode of the Epson TWAIN:
For scanning transparencies in HOME mode - for EPSON SCAN models, not Epson Twain/Manual mode models.
1) In the program you are working from, begin the scanning process. If working in FULL AUTO MODE as the scan begins click PAUSE or CANCEL, then change "Full Auto Mode" to "Home Mode".
2) You will now see all Epson Scan settings displayed. If the scanner has not previewed automatically, click the large preview button to get a visual of what is on the scanner.
3) Ensure the settings on the Epson Scan are correct for what you wish to scan. For example, the DOCUMENT TYPE for transparencies must be either "Color negative film", "B&W Negative Film" or "Positive film"*.
* FILM here indicates that the item being scanned is transparent to light; this setting is also used for slide scanning. Positive indicates that the image is in true colors (ie the grass is green and sky is blue), whereas negative indicates reversed colors, as produced in some photo finishing processes.)
If the DOCUMENT SOURCE is set for a flatbed related option, ie PHOTO, the scanner is looking for reflective items and will not activate the backlight in the transparency unit. If the DOCUMENT TYPES for "FILM" are greyed out or cannot be selected, close the Epson Scan, reseat the power/communication cable connecting the base of the scanner to the transparency unit, then reopen Epson Scan and try again.
NOTE for PROFESSIONAL MODE users: DOCUMENT TYPE should read TRANSPARENCY for film scans.
4) Ensure the other scanner settings are correct for the type of scan you are doing. For example:
IMAGE TYPE should be color photo for all positive or negative color transparencies, or BLACK AND WHITE PHOTO for monochrome transparencies.
DESTINATION is unimportant, however you should select a RESOLUTION appropriate to what you plan to do with the scans. (There are no hard and fast rules for DPI. As a general guideline, if you are saving scans at original size, a resolution ranging from 400-600 DPI should capture enough information to faithfully record the image. If the slide or negative will be enlarged, you will need to increase this DPI accordingly. We have no means to calculate what your exact needs will be in this situation; you will need to experiment and view the output to gauge the appropriate input DPI from the scanner.)
PREVIEW. If your scanner is doing a THUMBNAIL PREVIEW, the slides will automatically preview and appear in boxes on the left side. Here, you can select or deselect the slides you wish to scan.
If you recieve a message that the scanner could not find the film, or you see in the preview that part of the scan is cut off, click the down arrow next to the large PREVIEW button and click NORMAL, then PREVIEW again. In NORMAL PREVIEW mode, the scanner will capture all information on the flatbed; you will then have to manually marquee or crop the slides you wish to scan. Use the left mouse button (click, hold, drag) to lasso one slide inside a box made of dotted lines, then click scan. Only the selected area will scan. Repeat this process for as many slides or filmstrips are on the bed.
5) Click CLOSE once scanning is complete. The images will now transfer to the application in use.
Top Epson Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
NH TECH
Level 1 Expert
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
