One paddle turns very stiffly. Looking for a new pan unless there is a fix to free up the paddle.
SOURCE: Need new "paddle"
Hello this is Spur21,
Well you can purchase one at a service center. To find one access your internet and search for Black & Decker.
Good luck,
Spur21
SOURCE: B&D Bread maker all in one
I think the problem is that the bushing - the tubing that the paddle passes through - wears down (corrosion) and jams after a few years. I took mine apart and found that was the case. So a new pan has to be ordered. I'm trying that out now via the B&D 1-800 number.
SOURCE: I have the Black and Decker All-In-One Deluxe
There is a sealed bearing in the bottom of the bread pan. The paddle sits on the sealed bearing shaft. Over time the bearing begins to fail and the paddle does not turn freely or it may even freeze up. If you are sure everything is installed correctly this may be the problem. See if the paddle moves freely by hand and is not really loose. Sealed bearings can not be replaced. Eventually you will need a new bread pan. Sorry Hank
SOURCE: I have a Black &
maybe a striped gear in the bread maker or the drive pin on the paddel shaft,,
worst this i can think of is,,,,its putting you on a diet "shoot the thing?"
