I need capacitors for a Magnavox flat screen TV.
There are a number of online vendors for parts. I use MCM Electronics (www.mcminone.com) and Digi-Key (www.digikey.com) as well as a few mail-order houses. Radio Shack still carries a few capacitors, but likely won't have the values you'll need for TV work. You can also search for repair forums where you might find information for specific models of TV about the parts you need and sources.
When replacing caps, it's a good idea to go up to the next higher voltage rating and keep the capacitance the same. The part will be slightly larger but usually will still fit on the board. Under-rating is what usually causes these to fail in the first place, but manufacturers do it to save a few cents.
SOURCE: Magnavox lcd flat screen tv
Nope, don't think it's the speakers...I still get a black screen.
I had a similar problem with my 42 in Philips LCD HDTV.
Here was the problem. My Power Supply Board had several bad capacitors. I opened my TV (warranty was expired of course) and found four bulged capacitors on the PSB. Many major electronics companies Philips/Magnavox, Sony, Panasonic, and others were sold capacitors that failed in 2-5 years instead of 10-20. The capacitors fail prematurely due to a lack of preservatives. Unfortunately, they were installed in all sorts of devices and cause a wide range of failure problems.
Here are some options for you.
1. Have it fixed by a professional $$$$$$$??????? (Is it under warranty?)
2. Open your TV and find PSB. (The board that the power cord plugs into) Check for faulty caps. If you find some (bulged or leaking) bad caps replace the entire board. The entire board costs around $250 right now because they are in high demand right now. They can be found at tv-part.com but supplies are limited. I would definitely shop around though.
3. Remove and then replace individual faulty caps. This takes some soldering skill.
Caps are inexpensive and if you can take care of it yourself it will save you hundreds.
This may be your problem. If you determine that it might be.
I have a Tip/How TO tutorial on this site that may also help. It gives step by step instructions for replacing caps on PSB #715t2432-2. If this is your board you are in luck. It's called: Fixing the Philips Turns/shuts off on its own problem. I'm working on uploading pictures to help guide people though the process as well. Let me know if I can do anything to help.
Hope this helps and if it does please rate it accordingly. Good luck.
Kaufman605
