I have a dipping faucet in my bathroom tub. I need a diagram on how to fix it. its a single arm valve. The house was built in 1945 so the valve is about as old as the house. Please help. thank you.
Turn the water off to the residence and then remove the handle. After you remove the handle you can remove the retaining nut. When the retaining nut is removed you expose the internal parts that can be taken to your local hardware store and the parts matched. Usually, there are two small washers with springs up in the manifold that will need to be replaced. You can take your old parts in and usually buy a rebuild kit for it. If you aren't experienced, I would hire a plumber to replace the internal workings. It can be difficult if you cant get the retaining nut off.
