1. Press TV to select the TV mode.
2. Press POWER to turn on the TV. The STARTING SETUP function
begins and the language setup menu appears on the screen.
Press upArrow (^) or downArrow (v)to select your desired
language, then press ENTER.
3. Press (^) or (v) to select TV or
CABLE, then press ENTER.
4. Press (^) or (v) to select START, and
then press ENTER, which
starts the AUTO SETUP.
Note:
To cancel the setup and return to the regular TV screen, press (^)
or (v) to select CANCEL and press ENTER.
5. When the AUTO SETUP is complete, the regular TV screen
appears.
Notes:
• AUTO SETUP of channels may take 15-30 minutes to complete,
depending on your regional cable service.
• To cancel the AUTO SETUP and return to the regular TV screen,
press EXIT.
from TV manual that uses a CT885
http://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=4&ved=0CEcQFjAD&url=http%3A%2F%2Fwww.hdtvsolutions.com%2Fpdf%2F50hp66_om_e.pdf&ei=_KppUvWPNqjSyAHTr4DIAg&usg=AFQjCNGar3aphbJ5yNHl9QMUJsSI6SjCTQ&bvm=bv.55123115,d.aWc
