14291214 1421
1157 1307 1361
1046 1231 1047
Check these codes. If you wish to get more,
http://electrohelponline.blogspot.com/
http://remotesearch.blogspot.com/
Pull up previous posts, either by type in the Brand name to
your set in its search box, or view it in Mosaic / Timeslide / Flipcard option.
Select view option by the drop-down view box, at the top left or
the display window.
Setting Time
1 In the Clock priority mode, press and hold
TITLE for at least 2 seconds while the time is
displayed.
The time indication will blink.
2 Turn the Rotary encoder (CDE-9845/CDE-9843
only) or press 4 and 3 (CDE-9841 only) to adjust
the hours while the time indication is blinking.
3 When the hour has been adjusted, press the
Rotary encoder (CDE-9845/CDE-9843 only) or
press MODE (CDE-9841 only).
4 Turn the Rotary encoder (CDE-9845/CDE-9843
the minutes while the time indication is blinking.
The time is automatically set 5 seconds after the minute
adjustment. The time can also be manually set by
pressing the Rotary encoder (CDE-9845/CDE-9843 only)
or press MODE (CDE-9841 only).
• To synchronize the clock to another clock/watch or radio time
announcement, press and hold the Rotary encoder (CDE-9845/
CDE-9843 only) or press and hold MODE (CDE-9841 only) for at
least 2 seconds after setting the "hour." Minutes will reset to 00. If
the display shows over "30" minutes when you do this, the time
will advance one hour.
Or you can ge tthe manual on the link below.
http://a248.e.akamai.net/pix.crutchfield.com/Manuals/500/500CDE9843.PDF
Setting Time
TITLE/ for at least 2 seconds while the time is
displayed.
2 Turn the Rotary encoder (CDE-9846 only) or
press 4 and 3 (CDE-9842 only) to adjust the
Rotary encoder (CDE-9846 only) or press MODE
(CDE-9842 only).
4 Turn the Rotary encoder (CDE-9846 only) or
pressing the Rotary encoder (CDE-9846 only) or press
MODE (CDE-9842 only).
announcement, press and hold the Rotary encoder (CDE-9846
only) or press and hold MODE (CDE-9842 only) for at least 2
seconds after setting the "hour." Minutes will reset to 00. If the
display shows over "30" minutes when you do this, the time will
advance one hour.
